hey im trying to hunt down a miss fire in my rb25det
the car is a stock rb25det making 470rwhp at 26psi
last 3-4 weeks its been getting bad, now its time 2 do something about it.
basically the car from cold will start up and run on 5 cyclinders for first 10secs then clear up and run fine.
i can drive around off boost and it will run fine. As soon as i give the car a hard time and thrash it, i can pull up and on idle its back to 5 cyclinders.mind you it runs perfectly fine under load/boost
ive narrowed it down to cyclinder 6 which is the cyclinder not firing.
ive tried new injectors,coilpack wiring harness etc
injectors have been cleaned etc and new seals.
ive done a compression test and its good came back with 150-155 from 1-6
anyone else got any ideas? some ppl ive talked to think its lifter problem in cyclinder 6?
Edited by methz
https://www.sau.com.au/forums/topic/376360-rb25-miss-fire/
4350772539_55ff96415a_o.jpg&sa=X&ei=uotlTsuKKMLOmAXolZGaCg&ved=0CAUQ8wc4AQ&usg=AFQjCNGlgx_MfDkMMdcgSkJIa3LWOkL0Zw
Simon is making 500+hp on a stock motor? Misfiring could be caused by many things but it seems you've tried the basics. I will be keeping an eye on this thread to see how it progresses. Keep us posted. What I would suspect is the spark plug or coil back. Next would be wiring. Next would be CAS(could be playing up?) Sounds electrical to me. My car had similar symptoms on startup. It would sound like its missing a cylinder or even two and after a few seconds they all kick in, my spark plugs were on their way out. Try gap your plugs closer see if that gets rid of the misfire.
https://www.sau.com.au/forums/topic/376360-rb25-miss-fire/#findComment-6002873
plugs are about 500kms old bk7re always used them.
leak down test might be on the cards then, might ask my tuner 2 perform this.
yes 26psi thru gt35r on a stock rb25. i dont always run this boost. only turned it up for a dyno day not long ago.
running 1.75bar atm.
https://www.sau.com.au/forums/topic/376360-rb25-miss-fire/#findComment-6002980
At that power level I am assuming normal 98 pump gas? Simon is getting away with it on an ethanol mix, petrol would probably be a bit much for the crap fuel we get in this part of the world :(
+1 on compression test.
https://www.sau.com.au/forums/topic/376360-rb25-miss-fire/#findComment-6003033
yes pump 98 bp ultimate
car has been on big boost and 400hp for a few yrs now.
ive done 2 compression test's and both came up fine 150-155 across all 6.
leak down i have not done, i dont even know someone with the right tool 2 do it.
https://www.sau.com.au/forums/topic/376360-rb25-miss-fire/#findComment-6003068
Try a CAS and see. Just borrow a mates one if possible.
Have u upgraded the valve springs?
Does the engine tick when its misfiring?
Any smoke?
Do a compression test when it starts to misfire if u can. Maybe a valve seat issue
https://www.sau.com.au/forums/topic/376360-rb25-miss-fire/#findComment-6003438
Gonna try new CAS 2morrow morning.
Valve springs are stock
only ticking noise is from the injectors, as far as im aware
no smoke at all.
ill get it 2 run on 5 and do a compression test then and see wot it comes up with.
yeh my tuner thinks a lifter or valve or something along those lines in cyclinder 6
https://www.sau.com.au/forums/topic/376360-rb25-miss-fire/#findComment-6003477
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
