My Sabelt RAC steering wheel has arrived! I scored it off EBay for a measly $50!It was made in 07 and it looks to have been sitting around since. I’ll give it the treatment that it deserves.
Big, Black, Round?
  • Replies 231
yup BN Sports kit with modded standard front gaurds, veilside 50mm rears, bonnet vent, drift lip spoiler, custom tail light covers, blah blah. howd you get on with your extended lca? did you need to get longer tie rods? cheers
The man himself!
I put in some KTS inner/outer tie rods the same time I put the LCA's in. They are a little longer than standard too. But I don't know if I could run the LCAS without them sorry dude.
what is done to the front guards?
The 14th of November was finally in town. Mad Monday was here! Ben, Khoa and I got up at 6am eager to head out to Wakefield. We waited for another mate (Anthony) to rock up before heading out. It was a long journey, probably the longest I’ve driven the Skyline in one trip, It wasn’t too bad of a drive either which is good.
Anyway, after stopping for fuel (for both the cars and us) we got to Wakie around 9am. We unpacked our shit, signed in and passed scrutineering rather quick. This was the moment we have waited for. Lining up in pit lane to take on Wakefield.
The first few laps I was getting a feel for the track, then let loose. I really like the back section up the hill (turns 3,4,5 and 6). After our first session I rolled into pit lane and the car shut off, “Uh-oh”.
My oil pressure problem was still lingering around, in fact it was getting worse. So I let the car cool down for an hour or so before heading out again.
I felt it was time to take the car out again and see how it goes. Anth kept telling me to watch the pressure ”If your loosing pressure when giving it, bring it back to the pits”.
Again, went around the track a few times and let loose, after turn 6 I started watching the oil pressure and it was fluctuating alot, dropping lower and lower. On went the hazards and I drove it into pitlane. Once again the car turned off so I left it there for 20 minutes or so.
We then grabbed a bite to eat at KFC, and I was stressing out (as you would). We then came back and cranked the car over to see what was going on.
Started perfect, but had sweet f**k all pressure (1-2psi), We then noticed a tapping sound. So we killed the engine and got it towed home.
In other news, Benny drove like a boss! getting better and better each session. His car didn’t miss a beat. Me jelly.
http://www.youtube.com/watch?v=YPPRLkoS4Bk
In the video above, it was the first start since Wakefield. As you can hear, the tapping noise goes away. My main theory to what it was, was the lifters not sufficiently lubricated from the low oil pressure. Thankfully it sounds like that’s all it is.
Which means my engine has a chance at being ok. For the curious, the oil pressure during that vid was 20PSI. Pretty damn low. So the plan of attack this weekend is to fit a new oil pump, to see if that cures the low oil pressure problem.
I’m really pushing hard to get to Matsuri, and the good ol’ RB is giving me hope.
Yeah aftermarket gauge dude. Stocker doesn't work and are rubbish anyway.
Yeah here's hoping. I started it again last night and the sound is completely gone. I've had a car where the bearings shit themselves on me and yeah the sound only gets worse the longer the engine is on.
I'm going to drop the oil out tonight and see if theres anything interesting in it. If not then I think we'll be right.
What else can cause a problem liek this? oil pickup, failed Oring?
Well you have to drop the sump to change the pump anyhoo, so have a look at the pickup while you are there :)
Your new pump should arrive today...been sitting in a draw for a while so give it a good clean before you put it in (didnt have time to clean any dust out before I sent it sorry)
Hope it all goes well
The final piece of the puzzle arrived today, express posted from the ACT to my work. I got the front crank seal and gasket prior. Before the scheduled tear down on Saturday, I wanted to drain the oil to see if anything was in it.
Shortly after crawling under my R33, I had a look around the current oil pump installed on the RB25. Surprise surprise, there’s oil all over it, and managed to drip on part of the sump too.
Another thing I noticed was my power steering resivor. I guess I better get my power steering cooler in soon huh?
Oh right, the oil. I ran a magnet through it after draining, and it came up with no metal shards which is great! Here’s hoping the new pump sorts out the oil pressure issue.
New pump is in, but it didn't sort the issue. So I've pulled out of Matsuri and I'm expecting to either replace, or rebuild the engine at this stage.
Alloy rad was a champ, didn't go over 90 degrees but then again I wasn't giving it too much stick either.
There's a little missing before this post, but when I get a chance I'll do some updates to the blog. I've been rushing around franticly to get out to Matsuri this Saturday!
So, managed to get the head off tonight. Suspisions confirmed, headgasket is a goner. Interesting reason towards it though.
I don't know how, or why it would happen. But the head and block have been elongated in two parts (both on the passenger side). I'm guessing snapped head bolts or what not. So it makes me think why the head has been off in the first place. The piston tops look amazingly clean for a suspected 140k engine ... hmm.
Anyway, so the holes were elongated and a inner ring was placed in there to fill the new OD. But whoever has fitted this has also elongated the head gasket to suit. The photo below is probably where it failed, as it's right next to the water/oil jackets. So yeah as soon as we pulled the head gasket off and touched the enlongated part, the copper washer built into the gasket fell out.
So the plan of attack is to get another pair of inner rings in the same dimensions, cut two down to suit the block and leave the current two in the head. That way it'll still bolt together without needing to chop up the head gasket.
I need to get this car back together by tomorrow night if I have any chance of getting to Matsuri.
Fit inner rings, headgasket etc.
Reassemble head
Install manifolds
correct timing
change fluids a few times to get all the shit out of the system
Skids
Wish me luck boes!
lol, yeah I was talking about the dowel, stupid me.
Anyway, managed to get it all back together on the friday night. Fired it up and it was hunting for idle so we pulled the pin and headed out without my 33.
Got home yesterday afternoon, pulled the throttle body and intercooler piping off and saw that the plenum was missing those little rubber gaskets.
might fix that this week if I get the chance, then see what happens I spose.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
