Have the following parts left over after the sale of my 32 GTR -
1 x Full set of Agreve (Japanese brand) Damper and Circlip Height Adjustable shocks, brand new in the box, only opened to trial fit springs to 2 shocks. $250 bargain.
1 x Whiteline front Camber kit, suit R32 GTR, part #KCA328, brand new in packaging (opened but never fitted) $120
1 x Pair of M's pod filters/adaptors for RB26 $50 + postage
1 x Pair of stock R32 GTR RB26 cams, good condition (came out of my motor to fit Tomei cams) $200
1 x R32 GTR RB26 Crank Angle Sensor, working fine when removed (I put a 34 CAS in mine to suit the 34 Tomei cams) $50
1 x SX Fuel Pressure Regulator, purple, can get model # off it...was on my car working perfect when I bought it but took it off as I was going bigger injectors, comes with Speedflow fitting for the stock rail $200
1 x Full set of S15 200SX 16x7 stock rims in perfect nick, tires fitted but pretty much shagged, good for burnouts...$150
1 x Stainless rear muffler (barrel style) marked underneath but good condition otherwise, 5" tip, short length of 3" pipe welded on the inlet end $40
All parts are plus postage for interstate buyers, happy for SA guys to pickup.
0400 274 366.
Edited by NSNPWR
  • 5 months later...
1 x Full set of Agreve (Japanese brand) Damper and Circlip Height Adjustable shocks, brand new in the box, only opened to trial fit springs to 2 of the shocks. $200 - bargain.
1 x Whiteline front Camber kit, suit R32 GTR, part #KCA328, brand new in packaging (opened but never fitted) $100
1 x Pair of stock R32 GTR RB26 cams, good condition (came out of my motor to fit Tomei cams) $90
1 x R32 GTR RB26 Crank Angle Sensor, working perfect when removed (I put a 34 CAS in mine to suit the 34 Tomei cams) $50
1 x Full set of S15 200SX 16x7 stock alloys, perfect nick, Federal tires fitted but pretty much shagged, good for burnouts...$150
0400 274 366.
Items and prices updated.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
