No airbags for me so def going a full face.
Should have new rims in a week or so and then i just need to remove backing plates from the brakes (Makes a huge difference) Grab some spare pads, then install my new gearbox, get new Z32 then get tune checked. Change fluids then good to go. Taking the GTST out this time giving the GTS4 a rest. Keen to see how many Rb25's the little 20 can out perform :whistling:
  • Replies 412
All you NEED is an Australian Standards helmet. Which is a motorbike helmet, and you can go to any bike shop.
Autosport are doing open face helmets for $99, and that will be fine for most people.
You spend the extra money on an FIA approved helmet and itll be lighter, and probably more comfortable, but if youre only doing a couple of track days a year an AS helmet will be fine.
Cheers - hopefully late night shopping tomorrow night :P
I would advise highly on getting one if you are thinking of tracking your car. I have been running one on mine since the first track day and has not missed a beat. Oil temps seem to linger around the 90-100 degrees mark so it seems like my $200 cooler is doing its job after 6 consecutive hot laps
if you do not choose to run an oil cooler make sure you take some oil with you on the day and when you get to the track overfill your oil this will help prevent a spun bottom end bearing.
I would personally not go out to the track without one. :thumbsup:
I'd advise getting an oil cooler.
They definitely help keep temps stable. i've been using my Autobahn oil cooler kit, and it works no problems!
i havent had any issues with leaking or over heating.
people will tell you many different things like you need a thermostat because otherwise your oil is running too cool.
i dont have a thermostat and my oil temps are fine, obviously you dont go blasting the car when its cold! but if the temps are around the 50 degree mark its usually fine.
plus i assume when my temp sensor at the relocated oil filter is reading 40-50 degrees, the temp of the oil inside the engine is probably a little hotter than that?
Like Krishy said his $200 cooler is doing fine, so is my $400 cooler & relocator setup.
so its your call how much you wanna spend, but i definitely wouldnt risk not running one at the track. your car will be pushed so much harder than it ever would on the road.
Definately reconmend using one. On a hot lap after 3 cool down laps I was still seeing temps around 80 - 90 degrees
Interesting. After 6 hotlaps my temps were rouhgly 95-100 degrees mark and after one cool down lap it would drop to 70-80 mark.
Anything is better then nothing, so even if you can get hold of a cheap cooler is better than not running a cooler at all :D
Good power steering cooler probably isn't a bad idea either.
I've never seen my oil temps push over 90. And I keep my cooler smack in the middle of my rad and intercooler.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
