Once I get it back then it is due for a full service, new pads. So that will be oil, filter, brake fluid, pads, coolant. Than swap the wheels and get it track ready :D
Service @ Boostworx?
Also with wheels, I got new te37's and new tyres, should I
A. run te37's with new tyres or
B. use my old rims with new tyres (that means, undo the old tyres, put in new tyres, balance, then take new tyres off & onto te37s after track day? >_<
  • Replies 412
Depends, are they all the same tyres? How worn current ones?
No way, why pay so much for something that I can do at home :P I only use boost worx if a) I don't have time for it, b) Its something that I am not sure of and looks a touch difficult, c) CBF :P
Run the new wheels mate :D
bigkevracer Full Payment Received has personally asked to be put on the next track day as work commitments have come upon him, this is fine
so another spot has opened up
thank you for contacting me Ryan
ok guys we have had a couple of spots open up so that last remaining spots are open to anyone member or not
take this amazing opertunity to join the club at the track and see some other fast cars and talk to some great people about their cars
quick recap:
How Much: $200 PLUS an extra $25 for CAMS license
When: 7th November 2011
Where: Mallala Motorsport Park
Payment Details:
Name: Skylines Australia - SA Chapter
BSB: 105 192
ACC: 028 822 340
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
