  • Replies 412
Kuhmo KU36's are worth a look as well a fair few people ran them last track day and were quite happy.
Just make sure you lower your tyre pressures down to about 30psi, it took me three sessions to get this right and i was running street tyres. My tyres were overheating and feeling squirmy after three laps. Reduced the psi and was doing 6 laps confortably. Was running Michelin pilots for reference.
Rsr and ku36 both great for buck. At the moment I'm running both. The rsr feels better but will wear faster. Ku still feel good and extra k's is a plus if its used often.
The r1r's that vu mentioned are not worth the extra few hundred each, in most tyre places their the same price as the r888. A great tyre, but not worth the coin
If your happy to shop online the dublop direzza star spec,hankook rs3 and yokohama ad08 are all great prices from tirerack.com
http://www.tirerack.com/tires/TireSearchResults.jsp?width=265%2F&ratio=35&diameter=18
not a fan of KU36's, i found once hot they slowly get shagged.
RSR or toyo R1R i would go i reckon Andy :)
Haven't had that problem myself. And I've done a few track days on my current set of KU's.
R1R's while being quite lovely, aren't worth the asking IMO. May as well get a set of A048's if you're spending that sort of coin.
another vote for KU36 beng great bang for buck :thumbsup:
Yep another +1 here for the KU's
I ran the KU36's on my setup last track day and got the times down to where I realistically wanted to. Just make sure that you run the tire pressure a touch low to start with as they will get some heat into them :D
maybe the driver got better?
Anyway, whats everyone's "got-to-do" list before track day? :)
For me; helmet, tyres
Fit cams, buy and fit injectors, buy and fit 300lph+ fuel pump, roll/flare rear guards, drop subframe to replace diff and subframe bushes, shim diff, fit LS2 truck ignition coils, purchase and fit new clutch, empty and clean tank, sort the brakes out, have new dump/front pipe and intercooler pipes made to suit new turbo, align, fill tank with E85, tune.
Not too much to do...
Once I'm able to work on the thing again, most of that list will be done fairly quickly.
My to do List:
change brake pads (Hawk HT-10's)
Buy Helmet
Oil Change
Might need new tires by then, i've got R1R's they're awesome tyres. very grippy, and pretty reasonable wear (just need to get pressures right otherwise they wear unevenly)
I'll probably go for the Federal RSR's next just for a comparison, i'm not sold on the KU36 because they're a-symetrical and i don't want to have to trow tyres out because of camber wear.
i think one paper RSR's are probably closer to R1R's wear and grip so it'll be interesting to see how they compare.
other than those small things i'm looking at lowering times by driving better, hopefully wipe a few seconds off my previous times. ideally this track day i'd like to go sub 1m25s
Fit slotted front rotors, 850cc injectors, fit fuel system, wheel alignment, fix seat rail from sliding, fit z32 afm, get hard intake pipe made up, mount ls2 truck coils and wire in, clean tank, fill with e85, tune.
I'm in. Just booked annual leave.
Assuming it's ok can I just confirm about timer closer to the day?
Before the day I have a heap of stuff to fit: Shift kit, brakes (rotors, pads, braided lines), coilovers, adjustable toe arms. If I get to it I might also get the eManage fitted and tuned. Also need to fix the undertray at the front >_<
My aim is to get the car up and running again.
Here goes my list:
1) Get the diff working
2) Check the brake pads and possibly repalce it if need be.
3) Replace all the fluids
4) Take time off work.
apart from that no real issues really :D
I'll hazard a guess that my to do list is the biggest.. (pardon the crappy phone photos..)
(that thing wrapped in glad wrap soon needs to go in the big empty void in my engine bay) :P
Mines about the same...I still need to finish assembling the engine however. But everything is beginning to come together and should be on the road late Sept/early Oct :)
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
