More an Expression of interest at this point.
Happy to keep it but if the right buyer were to come along, I'd sell it with only two or three weeks of depression to follow.
The car is a 1999 - R34 GTR V Spec
Bought it about 18 months ago (give or take) with 48000km on the clock. That clock has since been replaced.
As a ball park figure, there would be between 70-80,000km on the car all up.
I'm the third owner in Australia, car belonged to another forum member prior to myself.
The car is in great shape save for a few issues that come with being 12 years old.
stone chips here and there, scratches where you'd expect to find scratches.
There's a small wear mark on the bolster of the drivers side seat and the diffuser lip has seen better days (See: http://www.youtube.c...ayer_embedded#!)
And a match head sized spot of rust under the brake light on the boot.
I'm Located near Parramatta
Email: [email protected]
Phone: 0408678265
Well, Ok then.
onto the details.
Engine:
Internals are stock standard with the following bolt ons:
Garrett GT2860R-7 Turbos
Apexi power FC with hand controller
HKS EBC and turbo timer
HKS Adjustable Cams
Split Fire coilpacks
Power enterprise 700cc injectors
Bosch 044 fuel pump
Apexi Pods
HKS hard pipe kit
apexi carbon cold air box
Mines carbon radiator shroud
X force split dumps
Impul Front pipe
Impul blast cat back
Gutted cat.
Brakes and Suspension, Tyres and wheels
HSD HR Coil overs - They get shit done
DBA 400 Slotted rotors
Project Mu carbon metal? rear pads
Endless CCA front pads
Standard GTR Wheels
Eagle F1 Symmetricals - 245/40/18 - More tread than you could ever possibly need (your results may differ)
In car there is:
Replaced the stock spedo with a 320kmh nismo item, because, well, 180kmh seemed a bit achievable.
eclipse head unit with ipod controller (top of the range)
Boston acoustic front splits
Boston acoustic rear 3 ways
Clarion 2 channel amp
Alpine 4 channel amp
Pioneer 10 inch sub
To make your ears bleed and attract the attention of the womenz, police and elderly neighbors.
Car was tuned by CRD to produce a family and friend shattering 308.4AWKW
The car has been a pleasure to own and drive but interests change and I don't feel the same way about it that i used too (it's not you, it's me)
Car has been garaged through out its life with me, Regularly serviced and washed and polished regularly if not bordering on obsessively.
As i said, more of a EOI than a FS thread, FYI DVD BBQ. But if i had to pick a number out of the air, I'd be asking $61,351. Because I can
Now! Pictures!
Some of these are a bit old.
Edited by Mosullivan
https://www.sau.com.au/forums/topic/376516-r34-gtr-v-spec-1999/
Hi, where in sydney are u located? I was after a blue one originally but starting to consider other colors.
Is the chick included for the $61,351?
Edited that in now, I'm not too far from Parramatta.
I'm not saying that if you buy this car, you'll turn into an armani wearing millionaire jet fighter with women like that falling over around you
But i'm certainly insinuating it
Also have some parts laying around that were going to go into this at some stage. Can always negotiate those into the sale to sweeten the pot.
for example, still have a triple plate clutch and a HKS oil cooler here.
  • 3 months later...
truly I would, seriously... if the missus didn't already have my balls in a vice
my next car may as well be a people mover >_<
Forgiveness is so much easier to ask for than permission
  • 3 weeks later...
LOL
The lady in the bikini looks very fore-giving :P
I trust you'll get the right buyer at the right time Matt!
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
