Year: 1994
Make: Nissan
Model: 180sx
Milage: 140,000 kms
Transmission: 5 speed manual
Colour: White
Registration: Vic 08/12
RWC: I MAY be able to negotiate a Vic RWC
Engineers Cert: It has an engineers certificate for most of the mods, however this was done by John Wilson of ACT in 2008. John Wilson is on Vicroads' list of VASS signatories.
Price: $12,500
Contact: 0431320142 or PM
Engine
SR20DET- rebuilt at 126000kms with reciepts
Dyno sheets showing: 273rwkw @ 20psi; 235rwkw @14.5psi
CP forged pistons
Brian Crower econo billet rods
Powerbond underdriven harmonic balancer
Balanced
Gktech rocker arm stoppers
ACL thrust bearings
ARP main studs
Tomei pon cams: 260 In/Ex 12mm lift
Tomei pon cam gears
Brian Crower titanium retainers
Brian Crower valve springs
Port and polished
Cometic metal head gasket
Garrett gt2871r .86 rear housing
6Boost exhaust manifold for low mount - HPC Coated
X Force Dump Pipe - HPC Coated
3" stainless exhaust with high flow cat
Bosch 040 Fuel Pump
PowerFC Djectro (maffless tune. No AFM) & Commander
Nismo 740cc Injectors
Nismo FPR
Bosch 040 fuel pump
Cooling PRO Front Mount Intercooler
HKS SSQV BOV
K&N pod filter
Custom oil catch can
Drivetrain, Suspension and Brakes
Greddy Type S adjustable coilovers
S15 steering rack
S14 LCA
Tuneagent pillowends with Tuneagent tie rods
R32 GTR front Calipers & rotors - 5Stud
S14 rear calipers & rotors - 5Stud
S14 5 spd gearbox - grinds a little into 4th when warm
ORC 409 clutch
17x8.5 Advan RG rims - gold
Interior
Bride seat drivers side - a bit rough
Apexi turbo timer
Greddy Profect B boost controller
Some parts removed but will be supplied - rear seat, boot floor, spare, tools
General
Body and paint are in good condition... just a few minor bumps and scuffs. It's no show car but it scrubs up alright!
Interior is ok. The dash is cracked and the Bride is looking a little rough. Otherwise it's not too bad... carpet, seats and trims are pretty good.
Pics up soon.
https://www.sau.com.au/forums/topic/376519-1994-180sx/
I am negotiable on the price... really just need the money at the moment. I MAY consider selling cheaper with the turbo, manifold and exhaust replaced with stock items; maybe the brakes, hubs and rims too... oh, and rego.
Edited by jimtron4000
https://www.sau.com.au/forums/topic/376519-1994-180sx/#findComment-6010126
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
