Forsale Items:
Rb20det Turbo plus aftermarket stainless steel dump pipe can sell seperate. Comes with rubber front comp hose. $200ono
rb20det injectors came off low km motor and rb20 AFM. $150 for both or $80each
Rb20 aircon pump with lines seen them up here for $200ono
Brand New for BA falcon thermos. Bought but never used have been sitting in box. on ebay for around $220pp. $200 posted
To4e Turbo (unknown brand) large came off a mates rb25 made good power. Good condition. $200ono
Drifttek single rim 17x9 5x114.3 black. No gutter marks perfect for a spare. $150ono
Lenso set for 4 rims black 4x114.3 comes with two rear spaces to get good offset on a 31. Tyres are ok. Rims have no marks look brand new. $600ono
Some 17 inch chrome rims with good kumho tyres came off a subaru liberty. Two tyres have slow leaks from memory. $500
Fuel reg with earls fittings $50
JJR 38mm external wastegate with customer long screamer used once or twice on dyno. pretty much brand new. suits SR or RB20 $200
HR31 front suspension complete. Comes with lower control arms aswell. Good on a 31 for 32 front brake upgrade $offers
R31 F&R full struts with lowered pedders springs. Good condition no knocks or noises.$200ono
R31 2.5-3inch dumppipe suits rb20 low mount stantard setup.$50ono
R31 standard Handbrake everything front handle to caliper. $50ono
Contact
Pm offers and questions
Call 0423 518 815 for sale.
Can post.
post-67045-0-68466600-1315460733_thumb.jpgpost-67045-0-30774400-1315460742_thumb.jpgpost-67045-0-43474200-1315460749_thumb.jpgpost-67045-0-93411600-1315460756_thumb.jpgpost-67045-0-12686500-1315460762_thumb.jpgpost-67045-0-03337800-1315460769_thumb.jpgpost-67045-0-92130200-1315461084_thumb.jpgpost-67045-0-89223700-1315461220_thumb.jpg
All the rb20 parts are off a silvertop out of a 32 had 85 XXXkms. Struts are HR turbo import struts they do have 100mm spacing to run 32 brakes
  • 1 month later...
  • 4 weeks later...
  • 3 weeks later...
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
