We just bought an R53 MINI Cooper S for my wife and it is awesome to drive.
180 odd bhp, sports suspension and 1100 kg.
I had a blurr to sell my 540 bhp R33 GTS-T and get another Cooper S and tweak the bejesus out of it.
Maybe I'm drinking too much cheap wine.
Any help, much appreciated.
cheers
id say just do a long awaited mod to the skyline...
New rims n mad sticky tyres? some kit? leather interior?
something to fan the flames of passion that any of us would die for to have a 540hp 25/30 (you bastard):thumbsup:
HaHa, Love your comment, Thanks man, I get it.
Well, I've really nothing left to flame, it's all done.
Suspension,engine, brakes, rims and tyres.
So do I start again with another project and burn another $50K or go for a GT4088 twin scroll + NOS on the 3.0.
Hey if my wife gets a wiff of any of this I'm FUBAR. :rolleyes:
Edited by conan7772
hey, you got her a mini, she ain't complainin
if you have the readies for it why not soup up something a little different? like a Delorean or an imported Crown vic and make it look like a legit NYPD cruiser...
theres my dreams outed anyway..
you realise if you put NOS in you'll have to get 2 of them... the big ones..
or as the cop says, get an EVO and go all time attack on it. .giant wide body kit, huge wing etc. dont forget the NOS either..throw about 100k under the hood, no one could take you, not even a Jetta!
oh and rb25, would i be allowed to roll around with cop lights on my ride as long as it was marked as a foreign LAC? as in yank?
keep your gtst-t and tweak your wife's mini
best of both worlds
damn right mate,
I'd rather cut off my right arm than sell my GTS-T
I mentioned tweaking the MINI before but she is strongly against it, she loves it just the way it is.
So I have to do it behind her back. HAHAAAA
I'm gonna order the 15% reduced pulley for the Supercharger, do a high flow intake and have it remapped on a dyno.
Will be interesting to see if she notices.
Don't worry, if she hits me, I'll hit her back. :thumbsup:
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
