Hey guys,
Hoping someone here has experience with Greddy Type-RS bov fitting.
A bit of a silly question....but I recently bought this:
http://www.ebay.com/itm/400236068871?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_2739wt_1163
to replace my stupidly oversized and loud Tiel bov.
It uses the same adaptor and is the same size as the Greddy Type-RS as I've seen here:
http://www.skylinesaustralia.com/forums/topic/333955-nissan-skyline-r33-r34-rb25det-greddy-type-rzrss-bov-adaptor/
Both say its 'simple' bolt on - which yeah it is, but im having trouble recirculating it.
When I fit the adapter & Bov, it's either facing straight up, or straight down - with the recirc pipe, of course being down the side.
The only thing I can think of is some sort of 90degree bend silicon hose to the recirculation pipe?
https://www.sau.com.au/forums/topic/376616-recirc-for-rb25det-bov/
You use o be able to buy a recirc kit for the genuine greddy bovs. Check the greenline website because that's the last place I saw them.
Pretty sure it's a 90 degree bend and some oter stuff but don't quite remember.
Otherwise if your handy you can make your own adapter.
Or I have a crossoverpipe with the holes tapped into it to bolt a greddy type RS (rip off) straight on in the stock position. I think I still have it anyway
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
