Hi guys i just bought 2x 2860-5 turbos from GCG
part no. 707160-5005
Now i opend both boxes and noticed on both turbos the wastegate arm is welded... wouldent this cause constant boosting ? im not 100% knowledgeable on turbos please help!
attached is the photo they both have this welding
https://www.sau.com.au/forums/topic/376621-2860-5-issue-brand-new-turbos/
the part number 707160-500 (5) or and (s) cant tell its hand written
the other part no. on the other box is the same but has an additional (s or 5 on the end) lol
maby one turbo is a little different to the other so they support eachother rather than be the same shit ? eg one will boost a little later to help top end power? noidea man having a stab in the dark....
Ash i dident pick up HD actuators their standard adjustable... can u explain the difference with the 2? why do i need heavy duty ones?
:unsure: hand written on the id tag???
So on the box has 5 characters after the dash right?....the last one is most likely an S as it seems to be part of the new labelling but does not always appear on the id tag on the unit itself
These turbos have to be EXACTLY the same for it to work properly paired on a rb26
You mean the boxes are hand written like mine were. Are the Id tags on the turbo's exactly the same or different? Both number sets on my boxes were different and my tags on the turbo's are different too. Still not 100% sure if they're the same turbo's or not.
post-58307-0-48648900-1315610219_thumb.jpgpost-58307-0-97417200-1315610253_thumb.jpgpost-58307-0-35815500-1315610274_thumb.jpgpost-58307-0-89404700-1315610297_thumb.jpg
heres a shot of the sticker on the box to clear up some confusion lol
and with regards to HD actuators .... when i pulled the arm off to see if the wastegate flap opend it took me and a mate to pull back on... im pretty sure this means its HD lolol post-53107-0-76262600-1315611005_thumb.jpg
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
