  • Replies 127
It's mainly used for circuit work here in SA in the local time attack series. Also used for fun in some hill climbs. Good way to destress on the weekend.
This car will be perfect for PI - hope to see you there in July for the WRX/SAU club sprint :cheers:
You have no idea how much I hate you right now you lucky duck :-( That's my dream car right there my heart is now broken :'( ...... All jokes aside mate I'm happy for you and that's awesome :D Good luck and if you don't post vids there will be MAYHEM :D
Edited by sikmatesubwoofa
Is there a better way to start 2012 ?? I think not... and so it begins...
AMS Alpha V-Band Manifolds:
AMS Alpha 12 Downpipes:
AMS Alpha 12 turbochargers:
The Pièce de résistance..... 1 x Alpha 12 Engine:
More to come as we start getting it all together....
  • 4 weeks later...
Note: Mods required (substantial compressor cover mods, new turbo drain required, custom silicone etc.) to make one of these Alpha systems work in RHD form. They are not a straight fit into any ADM/JDM GTR so be prepared for that if you invest in such a thing :turned:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
