  • Replies 127
It's mainly used for circuit work here in SA in the local time attack series. Also used for fun in some hill climbs. Good way to destress on the weekend.
This car will be perfect for PI - hope to see you there in July for the WRX/SAU club sprint :cheers:
You have no idea how much I hate you right now you lucky duck :-( That's my dream car right there my heart is now broken :'( ...... All jokes aside mate I'm happy for you and that's awesome :D Good luck and if you don't post vids there will be MAYHEM :D
Edited by sikmatesubwoofa
Is there a better way to start 2012 ?? I think not... and so it begins...
AMS Alpha V-Band Manifolds:
AMS Alpha 12 Downpipes:
AMS Alpha 12 turbochargers:
The Pièce de résistance..... 1 x Alpha 12 Engine:
More to come as we start getting it all together....
  • 4 weeks later...
Note: Mods required (substantial compressor cover mods, new turbo drain required, custom silicone etc.) to make one of these Alpha systems work in RHD form. They are not a straight fit into any ADM/JDM GTR so be prepared for that if you invest in such a thing :turned:
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
