Ok back to it...the latest fuel system required to feed Slips monster GTR at 30psi boost. Thats 3 x external pumps :)
Meet 'TRIPOD' :)
looks fantastic. I thought you were tripod down there though? is that mini tripod?
  • Replies 127
When SlipR35 takes his car to the track for a shakedown.....its not anywhere close to home - Adelaide - instead its Hidden Valley in Darwin. Car ran on the track all day today, Dean Canto punched out some laps, all in a great session in warm conditions and it still goes! :)
Two days of track testing and adjustment of Slips R35 completed at Hidden Valley in Darwin. I sat back here in Adelaide and went through the downloaded data after every run, made some changes and sent any software changes back. A few hunded litres of E85 down, and not a single failure :)
Ladies and Gents, This is the only Alpha 12 in Australia and it is now on the market, currently registered in SA. Many $$ have been invested in this vehicle since new. Serious offers will be considered. Specs can be found on the first page of this post. Updated with the latest gen Syvecs. Absolutely awesome car to drive.
Seb has split personality!
Not getting to drive my GTR...........................FOR SALE.
Driving my GTR..............................................you're #%@$#^* dreaming, hands off!
love/hate relationships are the best........... I suppose it must be like living with a playmate.
You dont get much hands on time.....................but when you do its totally awesome.
hang on to it mate. you know you want to.
BTW. What's the changeover price on a lightly modded 2011 model with upgraded headlights & a titanium rear?
No, actually a Temora 1000 run in proper controlled conditions :)
Going fast on the road is not cool in any way
so is he going to enter? wouldn't ratio's need to be changed for top end? and no i don't condone speeding on public roads
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
