Hi all,
I was having issues with my RB30DET related to knocking/pining.
http://www.skylinesa...1076-rb2530det/
These issue have been fixed now, however now I have a new problem. My setup will simply not make the power it should/did on another car. Its as if it is hitting a power "ceiling".
My setup is as per below:
Parts
R32 RB25DE head
RB30 Series 2 bottom end
RB26/30 CP Pistons 9:1 Static CR (CP pins, rings etc.)
Spool RB30 Rods to suit. ARP fasteners
ACL Race series bearings to suit above rods
Standard Crank. Blueprinted/Balanced/Crack tested etc
RB25DET Series II Oil Pump with extended drive "Snout" (Spool Imports)
GT3076R 0.82 A/R Garret Turbocharger (Standard oil/water lines)
Stiffer valve springs (unsure of brand)
High Energy Style Sump + Head drain (big f**k off fitting on the back of the head)
Standard valve train (RB20DET) (Cams/gears/lifters etc)
Cometic Head gasket (Spool Imports)
GTR Waterpump
550cc Bosch EV14 Injectors
Nismo Fuel Reg (Adj.)
Nismo Engine Mounts/G-Box Mounts
Bosch 040 Fuel Pump
Nistune ECU Remap
Labour
Bore/Hone Block to suit CP Pistons
Deck Block
Grind/Blueprint Crankshaft
Balance Pistons
Micropolish Crankshaft
Balance Motor
Reconditioned Head
Modify/Weld/Machine Head
Now no matter how much boost, timing, fuel etc. the tuner threw at the motor, the car will just not make anything more than about 210-220RWKW. Don't get me wrong its decent, but its no where near where it should be. This exact turbo on Cube's RB30 made (on standard RB25DE cams) 260RWkW. Id expect something a little less than this considering that I'm running RB20DET cams instead. I would also expect it to make it on less boost considering that I have a higher static compression ratio than him.
To my knowledge the motor is running 20-22deg ignition timing on full noise, 18PSI Boost, and the AFR's are sitting between 11-12:1.
Run more timing and the thing wants to ping but make no more power.
Run more boost and it makes little to no (few kW) difference in power and just generates more heat.
Run more/fuel (within reason!) and it only makes a few kW difference in power.
Another interesting fact was that previously when the motor was knocking, it was making 220kW on approximately 8 degrees worth of ignition timing. Which to me would seem as tho the car had been incorrectly timed (CAS error etc.) and that the motor was ACTUALLY seeing something closer to 20 deg of ignition timing. But I cant state that for sure...
We are dropping the exhaust/intake to see if there is a restriction in there somewhere limiting the setup. Failing this...Is there any other ideas/experiences that people have had hitting this "ceiling" with similar setups on RB20/25/26/30's?
Edited by R32Abuser
https://www.sau.com.au/forums/topic/376666-power-ceiling-gt3076r/
  • Replies 88
One of the cams is probably out a tooth
how does it drive?
out of curiosity. Ive just got my 25/30 up and running . un tuned still running rb25 tune.
I hear that they hit full boost 2.6-2.8k with a 3076R.
I am currently nowhere near that lol., I am presuming its because it is still yet to be tuned ?
I bet it is running as lean as f**k, mine did with the 25 tune in it. Stop driving it or get it to a tuner stat.
yer man. my narrowband hits the lean as soon as she comes on boost.
i was picking that as she was starving for fuel/ no timing put into her created the extra lag,
tune time next week, should woop it into gear
not unless your only running 5-10psi. in the real world they make 1 bar around 3200-3500 depending on the setup.
No matter which way you look at it the next step is to drop the exhaust and see what happens
DVS JEZ
The pinging/knocking issue was alleviated once we fit the RB20DET cams, new CAS, and re-timed the motor. Which one solved the issue I don't know. Im just glad it is no longer pinging to be honest and the fact that the pistons weren't the issue after all worship.gif
Intake setup is as the following pictures:
No rubber intake to turbo. Solid 3" aluminium pipe. Other than that, standard on the intake side besides a hole in the airbox. Possibly routing a big arse PVC (painted black) pipe setup straight into the airbox. May do this if it becomes an issue for power.
Dyno Im unsure of but here is the link to the site:
http://www.morpowa.com/dyno_dynamics.html
Tyres are as follows:
R: 235/45/R17 Bridgestone Potenza RE001 Adrenalin. Practically brand new.
kitto
Standard RB20DET cams. Possibly upgrading to custom re-grinds down the track pending how this setup goes.
sriver killer
I haven't driven it myself, but from what Im told drives very well. Nothing too ball tearing as its down considerably on power, but torquey as! Apparently (according to Cubes) this turbo will hit full boost 16PSI by about 2800-3000RPM.
Overall this could be a cam issue. If dropping the exhaust/intake doesn't fix the issue, we will be checking the timing again to make sure.
Exhaust s fine. 3.5inch turbo back with 100 cell cat.
1 bar at around that RPM is what I am getting, 4th gear on highways only though.
DVS JEZ
http://www.morpowa.c...o_dynamics.html
kitto
sriver killer
I am picking as I have the 25 tune the timing/fuel delivery is way out. giving me the unnecessary lag.
Driving around town the 30 is THAT much better to drive.
You would't think the difference that 500cc+ extra crank weight could be so noticable. Even with the 8.3:1 comp ( I am running new cast standard pistons)
Btw it probable doesn;t help my delivery that I have a 6boost, + plazmaman, + 3 inch intercoolerpiping + 4 inch thick intercooler
IMO a 4" thick intercooler and 3" piping is overkill for your power level. Obviously this will depend on what your using it for (street/track/drift/dyno queen). Either way, the time/airflow required to pressurise/fill these pipes would kill your delivery if you were aiming for near stock spool times. I assume that was what you were aiming for with the GT3076R turbo choice?
6Boost plenums from what I have read tend to promote power generation higher up in the RPM range as opposed to down low. So yes, this would not help your cause either.
Edited by R32Abuser
The 4 inch cooler was a necessary upgrade as at the time, as my existing 3 inch china ebay cooler had pressure drop issues.
3076R was purchased as a good all rounder, I can;t justify a 35R as a daily driver turbo on a rb25
Ive had everything just in case I want to upgrade turbo in the future.
what do you guys reckon about the garret .70 A/R front housing(with drilled anti surge slots) instead of the hks style .60A/R front housing?
exhaust comment was aimed at the OP. yer you'll only get 1 bar at those revs under a lot of load. it'll be a fair bit higher in lower gears
6boost manifolds are generally better all round, i highly doubt you'd have noticeable more lag over a stocker
Yup. I knew it would be touch an go with a 3". Has been done before, but figured I would just sneak it in. We'll see if its the restriction come Monday (dyno that was supposed to be used on Friday was unfortunately occupied all day due to a head gasket failure and prep. for a race on the weekend dry.gif
Either way, I'm looking for a more conservative 3.5" cat-back system. Anyone know of a 3.5" off the shelf cat back exhaust which is not too harsh on the ears (read: retains a centre muffler!)?
Sooo...The plot thickens!
Exhaust dropped - Car made no extra power (210kW)
Airbox dropped - Car made no extra power (210kW)
Cam timing will be looked into...Builder is doing the rounds for some opinions for this problem.
Very Frustrating :rant:
Cube's old GT3076R....
GT3076R .6 Port Shroud Comp Cover .82 Internal Gate
3" turbo back exhaust, Bell mouth 3" dump
Dont have the CHRA number on hand. Can get that for you though when I see the car...
Been talking to Sydneykid and he said that there isnt one RB30 he has built that hasn't needed timing adjustment. In this case I spoke to my builder and he said that at most it would be out a tooth but he also mentioned than although the lines are 100% spot on...they are barely noticeable out of alignment.
Adjustable cam gears possibly an option?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
