ok so the common problem people have with c34 stageas and turbo timers is when the lights are on auto and the turbo timer is on and u get out the lights dont turn off even when u open the door you must wait till the car shuts down then open and close the door very anoying.
The easiest fix is put a relay on the earth wire {black wire} to the auto lights module behind the instrument cluster and hook it up to the ignition so when the turbo timer shuts down the lights go out no matter what. i wired mine up that way 1 week ago and works great.
i even covered the sensor on the dash with a black sticker so the lights are always on when i am driving looks better and safer
parts needed 5 pin relay
female spade terminals and crimper
screwdriver
test light or multimeter
relay pin 30 cut earth wire from auto light module
pin 85 ignition
pin 86 earth
pin 87a other side of cut auto light wire
have fun
https://www.sau.com.au/forums/topic/376688-c34-auto-lights/
Yep the cluster needs to come out and the box is just behind it held with one screw I don't have a photo of the relay that I put in but just get a normal automotive change over relay and follow my instructions and u can't go wrong
https://www.sau.com.au/forums/topic/376688-c34-auto-lights/#findComment-6008640
Weird I've never been in one with out it.... (Been in over 10)
Personally I wouldn't put tape over the light sensor on the dash either as this is also used by the climate control unit.
The sensor on the Passenger side is for the climate control, driver's side, auto lights.
https://www.sau.com.au/forums/topic/376688-c34-auto-lights/#findComment-6024977
  • 5 months later...
