hi guys im just wondering about how i would go about doing an engine transplant putting a GT-t engine in my NA r34 25gt.
i know buying a gt-t is a better option financially but i want to have an engine so i can work on it and then when im off my p's bang that monster in :P.
ok so my skyline already has the turbo brakes.
i should be able to get a GT-t loom ecu turbo for around 2k-2.5k
what else needs to be changed?
im also awear that the drivetrain will need changing but ill change that when it brakes. plus i think they're only 150 -200 from a GT-t wreck anyway :D
All answers would be helpfull.
Ps. i managed to get my NA coupe for around 8k with 116,000 kms (guy was going bankrupt) :P
https://www.sau.com.au/forums/topic/376706-neo-turbo-engine-in-my-na-r34-gt/
you might want to add a 0 to the end of the price for a 'drivetrain' from a GT-t wreck, unless you are simply talking about the diff and not the gearbox. generally the gearbox sells for more than the actual engine.
as for what you need, look in the how to turbo a skyline thread. it has been covered many times. whether the engine is a neo or not is a minor detail. all the procedures are the same between a neo and a non neo.
Don't Gtt and gt have same trans
No, I'm 98% certain the one used in the N/A R34 is an RB20DET gearbox. The RB20DET gearbox can take no more than 220rwkW, so if you want more power then that, I would budget for a GT-T gearbox.
I'm pretty sure you can just use the N/A R34 gearbox depending on your power needs. Someone can correct me if i'm wrong.
Edited by JDM34
Stock (factory) component comparison.
GTt > GTv > GT
2 varients of GTt and GT:
GTt and GTt-x
GT and GT-x
The difference between the "x" and non "x" models are strictly trim level with "minor" mecanical option. ie premium sound, privacy glass, front strut brace, rear wing, optional LSD for GT-x (handling pack)
RB25de NEO = GTv, GT
RB25det NEO = GTt
Regular brakes (Tokico aka hitachi automotive calipers) = GT
Big brakes (Sumitomo caliper) = GTt, GTv
HICAS = GTt, GTv
LSD = GTt, GTv, factory optional on GT-x variant.
4 speed tiptroninc automatic = GTv, GT
4 speed tiptroninc automatic (internally strengthened) = GTt
5 speed manual = GTv, GT
5 speed manual (internally strengthened) = GTt
note*
GTt, GTv: they both have the same rear suspension setup.
GT: Has the same suspension setup as an R33GTSt
is it an auto? trans cooler won't do much to strengthen the box (and won't do shit on a manual, don't think you can even fit one) as it comes down the the strength of the internals and generally not the heat. heat is usually more of an issue with constant acceleration/power, such as towing or drag racing where they load the gearbox up before launching, but even then it's marginal.
not too sure on shift kits, but i have a feeling that they may actually cause you to break something sooner. they put more stress on the gearbox. i could be wrong though.
hmm people say they actually reduce stress on the trans i know it sounds weird due to quick shifting one would think its kinda jamming the gears into place will it cost much to make the trans be able to withstand a turbo?
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
