hi guys im just wondering about how i would go about doing an engine transplant putting a GT-t engine in my NA r34 25gt.
i know buying a gt-t is a better option financially but i want to have an engine so i can work on it and then when im off my p's bang that monster in :P.
ok so my skyline already has the turbo brakes.
i should be able to get a GT-t loom ecu turbo for around 2k-2.5k
what else needs to be changed?
im also awear that the drivetrain will need changing but ill change that when it brakes. plus i think they're only 150 -200 from a GT-t wreck anyway :D
All answers would be helpfull.
Ps. i managed to get my NA coupe for around 8k with 116,000 kms (guy was going bankrupt) :P
https://www.sau.com.au/forums/topic/376706-neo-turbo-engine-in-my-na-r34-gt/
you might want to add a 0 to the end of the price for a 'drivetrain' from a GT-t wreck, unless you are simply talking about the diff and not the gearbox. generally the gearbox sells for more than the actual engine.
as for what you need, look in the how to turbo a skyline thread. it has been covered many times. whether the engine is a neo or not is a minor detail. all the procedures are the same between a neo and a non neo.
Don't Gtt and gt have same trans
No, I'm 98% certain the one used in the N/A R34 is an RB20DET gearbox. The RB20DET gearbox can take no more than 220rwkW, so if you want more power then that, I would budget for a GT-T gearbox.
I'm pretty sure you can just use the N/A R34 gearbox depending on your power needs. Someone can correct me if i'm wrong.
Edited by JDM34
Stock (factory) component comparison.
GTt > GTv > GT
2 varients of GTt and GT:
GTt and GTt-x
GT and GT-x
The difference between the "x" and non "x" models are strictly trim level with "minor" mecanical option. ie premium sound, privacy glass, front strut brace, rear wing, optional LSD for GT-x (handling pack)
RB25de NEO = GTv, GT
RB25det NEO = GTt
Regular brakes (Tokico aka hitachi automotive calipers) = GT
Big brakes (Sumitomo caliper) = GTt, GTv
HICAS = GTt, GTv
LSD = GTt, GTv, factory optional on GT-x variant.
4 speed tiptroninc automatic = GTv, GT
4 speed tiptroninc automatic (internally strengthened) = GTt
5 speed manual = GTv, GT
5 speed manual (internally strengthened) = GTt
note*
GTt, GTv: they both have the same rear suspension setup.
GT: Has the same suspension setup as an R33GTSt
is it an auto? trans cooler won't do much to strengthen the box (and won't do shit on a manual, don't think you can even fit one) as it comes down the the strength of the internals and generally not the heat. heat is usually more of an issue with constant acceleration/power, such as towing or drag racing where they load the gearbox up before launching, but even then it's marginal.
not too sure on shift kits, but i have a feeling that they may actually cause you to break something sooner. they put more stress on the gearbox. i could be wrong though.
hmm people say they actually reduce stress on the trans i know it sounds weird due to quick shifting one would think its kinda jamming the gears into place will it cost much to make the trans be able to withstand a turbo?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
