GT Gearbox won't last long with increased power. Any little-to-mild flaring issues will become much more noticable very quickly.
I ended up going down the rebuild path with my gearbox in the end with HD Kevlar Clutchpacks, HD Bands, new solenoid set, and valve body upgrade. Handles it like a dream since. BUT that cost $3300 and if I did it again I'd get a low-mileage R34 GTT Box and valve body it.
Advice I was given by the performance auto specialist was a valve body can either improve and strengthen, or make worse and weaken an auto box. My auto was flaring quite bad, adding extra power didn't help. Third gear wasn't in a good state. A valve body upgrade would have just done it a lot worse and prematurely ended the gearbox.
Get a low mileage Auto GTT Box in good nick, do the valve body upgrade, and done! If you plan to give it on the track invest in a transmission cooler and temp gauge. I haven't done so yet myself, but that's just purely down to funds. Heat kills autos, more power = more heat... you do the math.
btw, I've just ordered an R34 GTT Front Cut Including Loom etc.. minus the GearBox, and sourced an Auto GTT ECU.
Hopefully next week or so the mechanic will be ready to do the swap and I can shed more light on the issues that arise or may not arise... But as stated before, gearbox will definitely be your first weak link when increasing power so if you haven't rebuilt your gearbox (expensive job!) try and get a half cut including gearbox and do a valve body upgrade.
Not wanting to be a thread hijacker here... but while this is on the topic of dropping a neo turbo engine into a N/A Neo: what is the difference between the wiring loom and ECU pinouts between the RB25DE NEO and RB25DET NEO? Reason being I currently have a Piggy Back eManage and would like to be able to transfer that accross to the new ECU without re-wiring the entire unit, obviously to save money. Would using an existing loom be ok, or is it going to be a case of change loom, change ECU and resplice the eManage harness on likely the same wires? That wouldn't be so bad...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
