2001 300gt sedan, was putting in another lighter plug in middle consol bit today went to start car incase batt was going flat and nothing, all dash lights,windows eveything working but wont start, had aa guy come out he told me theres no power going to starter motor, a month ago the alarm key got lost, have been using a normal 10$ key cut since and has been working fine, has somthing iv done triggered the immobiliser to go off maybe?
https://www.sau.com.au/forums/topic/376774-help-car-immoblised/
Do your front lights flash after you try to start it - in which case it could be the stock immobiliser. Otherwise, if it's an automatic, could you have inadvertently disconnected the sensor which tells the car you're in Park (car will not start if it isn't in Park).
Just ideas...
Nope no flashing, yes auto, will have a look to see if i have
thanks
Just ideas...
Couldnt see anything had been disconnected all tho i didnt really know what i was looking for, noticed on the dash nothing is showing up where should say d,n,r or what ever, battery looks to have just died the first thing i thought when it didnt start was battery so i hooked jumper leads up and didnt do anything aa guy also tryed to, so with in 20mins my batt has died..dont know if this has somthing to do with it or just coincidence or what
thanks
If you have no dash lights then you have most likely blown a fuse. There is a tail light or wiper fuse i think in drivers kick panel so check there.
Have dash lights, was meaning where it has the little letter as to what gear your in is lit up but not showing any letter
It was a standard nissan alarm key, i was suprised it worked with a normal key as the alarm was activated when key was lost, when i unlocked door with normal key it beeped for a bit put it in ignition and worked,.
How did you just use a normal key and not your alarm key?
Your gonna have to get in contact with your alarm maker and get the override code for the alarm and then get another key asap.
if you can tell them how it happened - yes. the dealer fitted immobiliser should have been pulled when compliance was done. the other one (compliance fitted) may be simply hacked into place and quite easily removed.
without the car in front of me I am simply pulling straws.
i dont know if we have same complience thing here in nz, was looking under dash and found a nissan alarm box, but theres a few wires going here and there that definatly dont look factory, guess ill get an auto elec to check it out and hope for the best.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
