2001 300gt sedan, was putting in another lighter plug in middle consol bit today went to start car incase batt was going flat and nothing, all dash lights,windows eveything working but wont start, had aa guy come out he told me theres no power going to starter motor, a month ago the alarm key got lost, have been using a normal 10$ key cut since and has been working fine, has somthing iv done triggered the immobiliser to go off maybe?
https://www.sau.com.au/forums/topic/376774-help-car-immoblised/
Do your front lights flash after you try to start it - in which case it could be the stock immobiliser. Otherwise, if it's an automatic, could you have inadvertently disconnected the sensor which tells the car you're in Park (car will not start if it isn't in Park).
Just ideas...
Nope no flashing, yes auto, will have a look to see if i have
thanks
Just ideas...
Couldnt see anything had been disconnected all tho i didnt really know what i was looking for, noticed on the dash nothing is showing up where should say d,n,r or what ever, battery looks to have just died the first thing i thought when it didnt start was battery so i hooked jumper leads up and didnt do anything aa guy also tryed to, so with in 20mins my batt has died..dont know if this has somthing to do with it or just coincidence or what
thanks
If you have no dash lights then you have most likely blown a fuse. There is a tail light or wiper fuse i think in drivers kick panel so check there.
Have dash lights, was meaning where it has the little letter as to what gear your in is lit up but not showing any letter
It was a standard nissan alarm key, i was suprised it worked with a normal key as the alarm was activated when key was lost, when i unlocked door with normal key it beeped for a bit put it in ignition and worked,.
How did you just use a normal key and not your alarm key?
Your gonna have to get in contact with your alarm maker and get the override code for the alarm and then get another key asap.
if you can tell them how it happened - yes. the dealer fitted immobiliser should have been pulled when compliance was done. the other one (compliance fitted) may be simply hacked into place and quite easily removed.
without the car in front of me I am simply pulling straws.
i dont know if we have same complience thing here in nz, was looking under dash and found a nissan alarm box, but theres a few wires going here and there that definatly dont look factory, guess ill get an auto elec to check it out and hope for the best.
