Hey guys,
I have noticed some rust in my engine bay in a very hard to reach spot. It will be hard to treat it properly without taking the engine out.
I have used sandpaper and a bit of thinners to remove as much as I can and have gone over it with a tiny paint brush but there are definitely some areas I have missed (my hand does not fit)
I am planning on getting the engine rebuilt in a few years time and was wandering if there is anything I can do/use to prevent the rust from growing any further until I have the engine out and can do the proper treatment?
https://www.sau.com.au/forums/topic/376781-rust-in-engine-bay/
Nah, shouldn't matter. I would take a stab and say you're only seeing a bit of surface rust, unlikely to be very deep. That said, get some fish oil on it and it will stop it from getting any worse.
You're kinda right. Fishoil coats the rust and surrounding metal which stops oxygen (in water) getting to it which is what causes rust.
It won't stop it completely, but will significantly slow it down. You need something to act as a sacrificial anode to stop it completely.
What does this mean? :P
You need something to provide the electrons to the oxygen instead of them coming from the iron that your car is made out of.
Rust happens when impure water steals electrons from impure iron (there are other reactions which can happen, but this is what's happening to your car). So a sacrificial anode will supply those electrons to the oxygen instead of them coming from your chassis rails :)
Where can I get me something to provide the electrons to the oxygen
Mmm....i don't think there's anything you can do. There are some electronic rust preventing devices around. In theory the make sense, but i don't think they've been proven to work in practice.
Try penetrol (available in spray can format) from bunnings etc.
The 4wd'ers love 'it. Some of them penetrol their bull bars and after 1 year of going off road and in salt water etc, no rust on their bull bars.
I tested some and it visibly repels water, pretty fun to play with lol. There's some other products from the same manufacturer but i think the spray can format will work best for you.. just aim and spray lol so no need to get your hand all the way in.
Zinc
Any zinc rich primer, such as Zinc-it or cold gal will give you some cathodic protection. Otherwise use the POV anti rust and pour old engine oil over it every time you do an oil change. That's what we used to do in Finland to combat rust on the salted roads back when I were a lad.
Zinc
Exactly.
Sand the surface rust back.
Spray some zinc rich primer onto onto the affected area. 2x coats.
Then a coat of under chassis paint.
If it's in a hard to reach spot ie. spray can cannot reach, just spray some paint into the can's cap and use a small brush to paint.
    • Just as long as it's not those putridly disappointing RE003s.
    • I had this same experience going from a set of no name tyres that were on a set of good wheels (Enkei RPFs) to some Potenza RE-11s (this was a few years ago). The wet grip in particular was so much higher that it was almost scary considering how dangerous the old tyres were in comparison. The expense of the tyres also made me want them to last longer so drove accordingly. Wife happy. So now she only 'lets' me buy some flavour of Brigestones...
    • This. All of this. I am turning >$300 into small particles inside 20k km, because I like to be able to roll around any 90° street corner at the speed limit. Would my car be more fun with cheaper tyres? Possibly. When I swapped out the bald AD09s for new ones, the change in the car was massive. The obvious one was being able to put the power down instead of lighting up into silly wheelspin. But the corollary of that was that the lateral traction went from being fun to fast. It was more fun when it was loose. But the corollary to the corollary is that if I need to dodge a child in the road or emergency brake to avoid the arsehat who has just tipped a GWM on its side in front of me, then I've got a much better chance of that manoeuvre coming off without unintended "fun" meaning that I hit something else, or the original target.
    • Every time I have to buy new tyres I question what actual difference it makes between running $40 tyres and $300 tyres and whether it's worth it. Because that's a massive difference to the wallet. But then I did go to a driving training at some point which also included emergency braking and swerving in the wet. In part I think it was meant to show people how bad it gets. Funnily enough what I took away from it is that I can go much harder than I thought in my car. I presume mostly because of decent tyres. Some of the other cars there were shocking to behold. And a bit scary that cheap tyres are probably a lot more common on the road than decent ones
    • I'm pretty sure that is just straight AI generated word soup, where did you receive that ad (facebook)? They misspell Pirelli twice, no human eyes looked at that before it was posted. Incidentally, I am running the chinese pirellis on my V37 and they are.....OK....I didn't go looking for them, they were just what the shop had in stock in the tall size that car needs. LIke any brand, you really can't trust the brand's reputation to apply to every product they produce. Pirelli make good and crap tyres, all with the same logo stamped on them, and all with an attempt at price premium due to the brand
