Hey guys,
I have noticed some rust in my engine bay in a very hard to reach spot. It will be hard to treat it properly without taking the engine out.
I have used sandpaper and a bit of thinners to remove as much as I can and have gone over it with a tiny paint brush but there are definitely some areas I have missed (my hand does not fit)
I am planning on getting the engine rebuilt in a few years time and was wandering if there is anything I can do/use to prevent the rust from growing any further until I have the engine out and can do the proper treatment?
https://www.sau.com.au/forums/topic/376781-rust-in-engine-bay/
Nah, shouldn't matter. I would take a stab and say you're only seeing a bit of surface rust, unlikely to be very deep. That said, get some fish oil on it and it will stop it from getting any worse.
You're kinda right. Fishoil coats the rust and surrounding metal which stops oxygen (in water) getting to it which is what causes rust.
It won't stop it completely, but will significantly slow it down. You need something to act as a sacrificial anode to stop it completely.
What does this mean? :P
You need something to provide the electrons to the oxygen instead of them coming from the iron that your car is made out of.
Rust happens when impure water steals electrons from impure iron (there are other reactions which can happen, but this is what's happening to your car). So a sacrificial anode will supply those electrons to the oxygen instead of them coming from your chassis rails :)
Where can I get me something to provide the electrons to the oxygen
Mmm....i don't think there's anything you can do. There are some electronic rust preventing devices around. In theory the make sense, but i don't think they've been proven to work in practice.
Try penetrol (available in spray can format) from bunnings etc.
The 4wd'ers love 'it. Some of them penetrol their bull bars and after 1 year of going off road and in salt water etc, no rust on their bull bars.
I tested some and it visibly repels water, pretty fun to play with lol. There's some other products from the same manufacturer but i think the spray can format will work best for you.. just aim and spray lol so no need to get your hand all the way in.
Zinc
Any zinc rich primer, such as Zinc-it or cold gal will give you some cathodic protection. Otherwise use the POV anti rust and pour old engine oil over it every time you do an oil change. That's what we used to do in Finland to combat rust on the salted roads back when I were a lad.
Zinc
Exactly.
Sand the surface rust back.
Spray some zinc rich primer onto onto the affected area. 2x coats.
Then a coat of under chassis paint.
If it's in a hard to reach spot ie. spray can cannot reach, just spray some paint into the can's cap and use a small brush to paint.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
