Hey guys,
Have a bit of an interesting one....
The oil from my gearbox keeps spewing out from the breather line which ends up near the top of the bellhousing. Bought the car with fresh shockprook oil put in and thought it must have been overfilled so i wiped away the excess, checked the oil level (just below the filler hole) and didnt take too much notice of it since. Now (2 weeks later since being wiped away) i had a look underneath the car and it's still spewing out. I've checked the oil level and its about 10mm below the filler hole, so its not overfilled.
Is there a small breather, like on a diff, on the gearbox that might be blocked causing excess pressure?
https://www.sau.com.au/forums/topic/376791-gearbox-pressure-build-up/
  • Replies 40
Hey guys,
Change the shockproof for something else. We had the same problem in both our race cars and a couple of customers cars that shockproof went into.
Yes, I have had the same issue with the race car....it continually breathes smurf blood
I read maybe 12 months back, there was a bad batch of shockproof. I've been running shockproof lightweight for 2 or more years and it's never spat a drop out the breathers
Interesting....I bought mine about 12 months back, and from a very dodgy shop. Got any more info?
Lol, had a fix to the issue in the race car?
I'll give it one more chance and i'll check back on it in a couple of days, if its still spewing it out i'll change to something different. Just seems hard to beleive about the supposed "bad batch", no offense moodles.
The gearbox seems to select all gears fine, the only sounds i can hear from it are when downshifting into neutral to a stop i can hear the gears/synchro whirring back down to the same speed (not a bad whirring).
Edited by joeyta22
sure....I put a breather/catch can up near the brake master cylinder...and refill the box after each race meet.....and degrease under the car often....and park it over an oil catch tray.
fixed easy!
the problem with SHOCKPROOF oil is that about 12-18 month's ago, they discovered that the main ingredient
that made it as good as what it was, was carcinogenic so they had to remove said ingredient and replace
it with something else, and it's never been the same since...
I also have this problem at the moment and the bell houseing gets caked in oil after just 1 week of driving and its been doing it for the 5000km (1 year) its been in there.
I think lightweight shock proof is not worth anything anymore because i saw a track evo the other week use it and after 1 day it came out black?????????
What the point if it cant stay in the box or if it can it just goes black with heat stress...........changing to AMSOIL SEVERE GEAR Synthetic Extreme Pressure next service.
how much $ was this? im assuming 3 litres
I get all my oil through Harold at performancelub as linked above, awesome to deal with, prices are good and sends stuff out very quickly. Mine took about 4.2L with a little bit of spillage.
Yeah give it a shot central coast person, sound like you have the same problem as i did.
Come to think about it ive been having problems with the gearbox in my 180 drift-pig spewing out shockproof aswell (havnt driven it in about a month), i always just thought i had a leak around the top of the case. Hmmm im sensing a common theme here...
Edited by joeyta22
The GTR/GTST 25 boxes should take about 3.6-3.8L
And don't tell me that you put 3L in your mates mates car and it was full. Drive the car around the block and check it again.
Most of the R200 rear diffs will take 1.6-1.7L front diffs in the GTR about the same but closer to 1.5
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
