  • Replies 127
in the city. pitt st and park near that maccas and opp galeries victoria. im in there a lot, have a hand held one already but its shite so considering an upgrade for the cruise.
are these prices good?
Eric I'm starting to think you are on crack with the organisations of this "cruise"
It's 6 hours from Syd to Wang and another 45mins from Wang to Shep. Now I do this drive quite regularly quite a few times a year.
I think you have your times out. The times between Phesants and Yass are out and the times between Albury and Shep are out.
There is no way in hell I'm going to be meeting at Phesants at 6.30 am that would mean I would have to be leaving my house at 5 am and be up at 4am!
Beau and I normally leave by about 10am when we drive down and normally end up at Wang at about 4pm this is allowing 2 stops including a lunch break and petrol.
+ your 45mins to get to Shep which would mean more sleep in time.
P.s
Castle hill to Phesants 1.5hrs
Phesants nest to Yass 205kms 1.8hrs
Yass to Albury 281kms 2.5hrs
Albury to Shep 175kms 1.6hrs
Being more realistic about the situation it is a long drive. calculating in stops and people f**king about I would say it would be more realistic for everyone to meet at Phesants at 8.30 for a 9am departure. That should get you in Shep at around 4 -4.30pm
well i'm relying on google which can be hit and miss. Also had to pin the petrol stations from the sat view. I think the times got farked. I havent done this pass so relying on that info. I need to recheck all the legs again.
as for starting time, much later for me (and others) and you're into commuter traffic that's unpredictable.
Well considering Beau and I pretty much do this run quite frequent we pretty much know the distances and times. The only traffic you are going to get getting on to the M4/M7/ whatever way you are heading to get to Phesants and getting in to Albury. Best place to stop would be BP at Glenrowan because its on freeway = no traffic. The rest is free way so you don't hit any traffic. Going away from the city.
yeah i go to bed so late there would be no point sleeping if we made it half six..any chance u could creep it 30 min to an hour or so later Eric?
on behalf of all the insomniacs on SAU...please...
Corinne that's pretty much what I said in the NSW thread about this (about meeting so early) but no one cared! lol :laugh:
I care Shell, Sorry I missed the post. :wub: I just think this plan is overenthusiastic. It would require most people to be up at 4am to get there on time.
4 am is a bit of an exaggeration. Doesn't take 2.5 hrs to get there unless you live somewhere up the central coast or beyond. But I get what ya mean. I'd have to be on the road by 5:30.
Can someone check this? I've re-done the google map fail thingo - I think it was a quirk that google will make you back-track sometimes if your stops get out of order. GOOGLE MAP
Maybe we poll folks about start time. Steve-O, Paul and Brett were pretty keenolio for the early start. I'm ok as long as we don't go beyond 8 am as I'll have traffic problems.
Oh, and my thought on those petrol stations on the way to Yass is that if you need petrol or to pee just stop and rejoin the group in Yass. No need to stop the whole group.
1.5hrs from castle hill to phesants but it would still take most people an hour to stuff around at get shit organise before they have to leave the house.
u need to lrn2trackday..
prep all the night before.. wake up,get dressed, wash face/brush teeth and out the door! done and dusted in 10 mins.
and no u dont need to do ur hair.. just open the window before u get to the meet and blame the wind :D
I do princess, I've been doing before you.
lol! i get up anywhere between 2:30am- 4am to go to work. i'm usually starting work most days around 5am so no biggie the earlier it is. means more drinking time the quicker we get there :P
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
