I have some leftover parts from my R32 GTRhalf cut. I pulled these parts off over a year ago and now they are just taking up too much room in my shed. Photos were taken after a quick wipe down with damp rag, can get better pictures on request.
I am located on the Northside of Brisbaneand would prefer pickup. However I am willing to ship at the payees expense.
I might have a couple of other piecesavailable (E.G. I have a really clean sump perfect for someone wanting tomodify one, but that is wont be available for a few weeks).
PM or sms on oh4oh4 oh1oh 832
RB26 Transmission, No Bellhousing, no crossmember, with front driveshaft, with shifter (no knob) $600
Transmission Crossmember $50
Dashboard (no vents) $75
Glovebox $50
Centre Dash section with Tripple Gauges $100
Guage Cluster $100
Gauge Surround $75
Steering Column plastic Surrounds (fusepanel cover supplied but not shown) $50
Under dash plastic $50
Kick Panels $50
Random A/C plastics $10
Ashtray $10
A/C Fan $30
A/C heatexchanger $30
Heater $30
Drivers Headlight (small hole made bycustoms, does not appear to have affected light) $50
Passenger Headlight (small hole made by customs, does notappear to have affected light) $50
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/
  • Replies 65
MAF sensors and hks pods with no elements $100
Turbos $200
Turbo intake pipe $75
Turbo heatshields $50
Nismo turbo dump $50
Computer $100
Wiring Loom, includes fuses/relays and allconnectors labeled $400
Clutch master $20
Aluminium Engine Mounts $50
Front KYB shocks with HKS springs $50
Steering Rack $50
Power steering pump and hoses $50
Sorry no photo, will take one soon
Front Hubs $100
A/C cooler with Fan $40
Radiator with fan shroud $50
Window wiper motor and linkages $25
Pedals (not sure where the other pedal is) $50
Steering Column $50
Half Shafts $10
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/#findComment-6009450
Hey mate,
I will PM you about the ash tray.
RE the Brakes. I have the ABS unit, you can have it for $125.
Also have some wheel speed sensors. The rotors and disks are being used and the booster I am using to mock up in my car, so wont be selling for a few months.
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/#findComment-6009507
Sold Parts
+ Gauge Cluster
+ Exhaust Pod Filters and elbows
+ Radiator Fan Shroud
+ Driveshafts
+ Steering rack
+ radiator
+ both headlights
+ abs unit
+ ash tray
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/#findComment-6014319
Sold Parts
  • Gauge Cluster
  • Exhaust Pod Filters and elbows
  • Radiator Fan Shroud
  • Driveshafts
  • Steering rack
  • radiator (payment pending)
  • both headlights (payment pending)
  • abs unit (payment pending)
  • ash tray (payment pending)
  • dashboard (payment pending)
  • power steering pump (lines and atessa still available) (payment pending)
  • AFM (payment pending)
  • ECU (payment pending)
  • Clutch master (payment pending)
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/#findComment-6017418
Sold Parts
  • Gauge Cluster
  • Driveshafts
  • Steering rack
  • radiator
  • dashboard
  • AFM
  • ECU
  • Clutch master
  • Hubs (payment pending)
  • Struts (payment pending)
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/#findComment-6020680
No cracks in gauge surround (not sure if clock works). Minor blemishes on centre console sides (tried to take photos, but they haven't come out real well). you could have both for 150
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/#findComment-6024725
hi, got my parts today, great to deal with, excellent communication.
would happily buy from again.
thanks again mate.
good luck with the sale of the rest of your parts.
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/#findComment-6034589
Sold Parts
  • Gauge Cluster
  • Driveshafts
  • Steering rack
  • radiator
  • abs unit
  • ash tray
  • dashboard
  • AFM
  • ECU
  • Clutch master
  • Hubs
  • Struts
  • AC Fan (payment pending, cooler available for $20)
  • Heater unit
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/#findComment-6036219
RB26 transmission $400
- No bellhousing
- With crossmember
- With gearstick (no knob)
- With driveshaft
Glovebox $40
Tripple gauges and plastic surround $75
Gauge surround $50
Steering column plastics $30
Turbos with heat shields $75
Turbo intake pipe $50
https://www.sau.com.au/forums/topic/376795-r32-gtr-parts/#findComment-6036322
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
