  • Replies 48
FARK I wish i had enetered my car! I was sitting on the hill for most of the drags and even with 3, 8sec cars either side of it, the skyline got one of the best responses of the afternoon!
"Ful sik bro...look at da line man.... fark.... ful sik bro!"
MRHELI did well too... loved the wheelstand... I hope someone caught that on tape...
Cheers.
https://www.sau.com.au/forums/topic/3768-9sec-wrxs/#findComment-61585
Originally posted by ONARUN
fastest ET was 7.96. black LJ Torana (there could have been a quicker one after 8, i left then)
poor showing from the Japanese performance scene. i would have thought there would have been more cars. only 1 skyline ran and it wasn't anything to write home about.
George I totally agree. I spoket to the organisers and they say it is a more of a V8 nationals then anything else. Majority of Jap cars were preparing for the jamboree and that should be bloody good though.
Good to see Rigoli and Pac and Mazda guys there! Well done to them and all the v8 guys too.
https://www.sau.com.au/forums/topic/3768-9sec-wrxs/#findComment-61963
Originally posted by Roy
I left at about 6.30pm. I saw a 200SX run , black i think that lifted off early because it looked as though its slicks were rubbing on the guards. Looked seriously quick ythough, like 10s.
Did it or the silver Lancer GSR run later in the night
ROy that was the croydon autosports 200sx running sr20det.
I was speaking to the mechanics when the car was just about to run. Its great being pit crew! It too ran a 9 second pass! Well done!
https://www.sau.com.au/forums/topic/3768-9sec-wrxs/#findComment-61967
GEEWIZ GSR?
i think that may do a low 13/high 12 if lucky, guy who owns it (its FS) is a soccer player for marconi
heh
https://www.sau.com.au/forums/topic/3768-9sec-wrxs/#findComment-62060
the R32 GTR, he is no longer allowed back on the track unless he races at Heathcote Melbourne which is an private track.
TRY09's did run a 10.06 @ 139mph. It will be at the Jamboree, going for a 9sec pass.
Croydon ran 9.70's at Heathcote at the Turbotitles a couple of months ago. very impressive car to say the least.
https://www.sau.com.au/forums/topic/3768-9sec-wrxs/#findComment-62177
Originally posted by nismogtsx
I saw the Try09 car on the dyno at the auto salon and have videos of it cranking out..... It was awsome....
They are gonna run 2 bar this weekend + NOS.
They will take the 9 second quarter easily.....
ne chance posting the videos?
https://www.sau.com.au/forums/topic/3768-9sec-wrxs/#findComment-62750
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
