  • Replies 45
Tech night explaining entry level motorsport covering things like;
-Different catagories
-Explain the rules and regs for different catagories
-Car choices
-Basic modifications to compete
Prob a few other things that could be discussed but i think that would be a good start.
Daniel
-Car choices
Daniel
wow thats such a good idea, i bet duncan wish he thought of it. :D
and as for the membership, i'm keen but it will have to wait till this drama with my lude is over. :)
oh man I am being stitched up good tonight!
Seriously though, intro to racing night with a couple of sample cars to pore over, and a quick overview of different categories and realistic budgets would make good night.
How about a theory based circuit night?
Something where people can ask a professional driver or two or three about racing lines, car control, setup advise etc etc.
You could run one before the eastern creek day so people can get some theory advise before heading out to the track....
Boz was looking at running one for trackschool, could easily be converted to a skyline specfic thing too.
Can you imagine it?
If you turn left and it goes rattle rattle your bearings are gone.
Turn right and the oil pump makes this noise "crack pop pop bleh"
hehe
Let me know the date :)
Any questions or main topics anyone wants us to focus on?
IMO A big point should be that simply whacking in some forged slugs and rods won't make an engine bullet proof.
and making a point that the machine work/clearences is 99% of what makes an engine survive and not those $$$11ty HKS pistons
basic maintenance?
Brake pad change and bleed
Coolant flush
Plugs change
Fuel filter change
Fuel pump change
Brake master cylinder change
yep they're pretty basic but i think a night which covers common consumeables for skylines now that they're getting a bit long on the tooth would be great. Especially for some first time owners??
This get's a big +1 from me. It may be basic stuff to a lot of people on here but for some us it would be a great starting point. One of the reasons I joined was to give me access to people and information that I just don't have in my normal circle of friends ( to many inner city tree hugging hippies )
I will be attending every Tech night I can but I'd like to get my head around the basic stuff first. I'm reading as much I can but you can't beat practical teaching.
I don't suppose there's any chance they can be filmed?
*Crosses fingers*
if they are please make em available to interstate members action-smiley-069.gif - id gladly pay for recordings of these :)
I would actually die for something like this to happen in perth, the only way I can learn about this is for me to buy a cheaper car to work on and just jump right in and hope for the best confused.gif i tried a short weekend tafe course on basic car maintenance but it was useless really.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
