Hey guys,
just drove to newcastle and back in under 24 hours to have a look around as im moving up there next year,
my girlfriend is moving 5 months before me so im going to be driving it ALOT and after that drive i really need cruise control, my lower back in absolutely killing me!! (im only 20)
has anyone done this mod? i couldnt find it in search bar.
i need to know, how much it costs, how hard it is to fit and pointed in the direction of a good unit.
just looking for a cheap and easy option seeing as ill probly be fitting it into atleast two cars.
https://www.sau.com.au/forums/topic/376826-omg-i-need-cruise-control/
Hey guys,
it can be done easy, nissan failed , they forgot that option..lol remember a hi power car on wet roads and cruise control is a dangerous mix even with 4 wheel drive on GTR. ?
I often wish mine had it but know its a bit dangerous if the boost hits on a bump or slippery roads. even with traction control on you could be in the trees in seconds
your back hurting would be more of the seat and or too stiff suspension. jap coilovers are really setup stiff they have smooth roads . my Bilstiens coilovers are shocking and have been setup reduced even. my GTT seats and my large frame dont match. I bought new ones , or if you have really tall rims and low profile tyres it trashes the ride quality too
australia has some horrible roads , the dirt ones are smoother sometimes.
i wouldnt do cruise control on a stick shift skyline, autobox maybe if not modded up a lot
i got a stock gtt, manual, stock wheels.
hmm yeah i thought that too but i spose i could move my legs around if i had the cruise control.
it wouldnt me to dangerous on a dry day in 5th gear would it??
the syd-newcastle fwy is an aweful road!!! an hour and a half of a steady foot. aweful!!!!!!!
the other option is buying a second car, ive been looking at the honda jazz. think that would be more comfortable??
i would prefer not to drive the skyline every fortnight for 600ish kms hah
thats my fun car! not my broken back car!
I'm not a fan of cruise control but when time/funds permit I'll be fitting cruise to the 32.
Nothing flash, just an AP60 and apart from the "on" switch, I'll only use a "set" button mounted on the gearstick.
Clutch and brake switches will be the kills.
Was concerned the vacuum style of cruise would give problems with a turbo engine but no, they work fine.
Been in Skylines a lot and unless you're Danny Devito, your legs will soon rub the paint off the driver's arm rest and your leg will cramp from holding the accelerator UP.
On the highway they just want to go faster as they're so smooth from 3000rpm on.
try a light rear end turbo power car on a hill in wet weather or bumpy roads, the boost comes on and your sideways(on cruise you need a traction cutout but it will be too late by then IMO) . Im 6'2 and sunroof in my car lowers the roof a lot. the seats are made for someone 5'3 ??so I feel your pain on space ... just take a break , a cruise is fine for a 4cyl camry but not a skyline turbo
This might come in handy. (I drive an auto skyline - so I imagine it will be much easier to install)
http://www.ebay.com.au/itm/CRUISE-CONTROL-AP60-UNIVERSAL-DIY-KIT-NEW-WARRANTY-/260850094810?pt=AU_Electronics_Accessories_Remote_Controls&hash=item3cbbe092da
I typed "universal cruise control" into google.
Love my cruise control in my gtt.
If you are coming to an unfamiliar crest click it off for a few seconds if it comes on boost then reset
If you are driving the same roads day in day out you can can predictict the cars reaction.
I must be missing something crucial here.:blush:
Correct me if I'm wrong, the cruise control is basically looking for a set number of pulses from either the ecu speed signal, or a magnetic pick up.
If the car came on boost and started to wheelspin or accelerate wildly, this would manifest in an increase in pulses; exactly what the cruise control is there to correct. Would this then not result in the cruise control releasing the throttle; thus eliminating the problem? Or is it more a case of the speed that the cruise control reacts?
Surely you guys aren't driving cars with so much power and response that they break into spontaneous wheelspin at 110km/h in top gear?:blink:
I would have thought an auto would actually be more of a risk for "surging" due to their ability to kick down a couple of gears unaided and end up on boost; versus a manual which will be more likely to labour a little.
When driving cars with cruise, I tend to give a little manual throttle on the lead up to a decent incline; to help it along, as they often fall off the torque curve before realising they need to increase the throttle opening to maintain the set speed, by which time speed has dropped by 10 -15 km/h. This is when you tend to see cruise control making aggressive throttle adjustments.
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
