hey guys, looking to get rid of my regoable track car.
Only selling due to working more hours and not being able to drive it as often as i should.
I have owned this car for almost 3 years and took it of the road due to losing my licence. car serviced every prac night with synthetic oil and filter, and plugs every 3 pracs as well as comp tested.
car has around 160 000 ish km on it speedo stopped working about 6 months ago, engine only has around 45 000 on it.
Mechanically the car has never given me any real trouble and anything else that has has been replaced.
engine:
s1 rb 25
splitfire coils
blitz injectors
z32 afm
tomei rising rate fpr
garrett 3037s, braided lines
turbosmart 48mm progate
6 boost exh mani
alloy rad
greddy cooler
oil cooler & relo kit, braided lines
fuel:
040 lift pump
044 external pump
alloy surge tank
driveline:
25 box
xtreme drift clutch
nismo 2 way 4.3 ratio
s14 rear cradle, solid offset bushes
solid diff bushes
suspension/handling:
33 brakes all round
project mu handbrake shoes
kazzama castor rods
custom shortened upper arms/nolathane bushes
cusco rear camber & toe arms
tien HA coilovers front & rear
front & rear strut braces
s14 lca's/boxed up
gtr rear swaybar
alloy steering bush
currently running stock 32 knuckles with s14 tie rods & ends
inside:
currently has stock seats but can come with Bride fixie on genuine Bride rail
deep dish s/wheel
boost guage
wheels:
front: work 17x9 +11 meshies with 90% ku36's
rear: work equip 18x9.5 +41 with shagged neutons
spares: 4x roh drift R's 18x8.5? + 38? all with 50% neutons
2x 17x8.5? + 28? equip's
2x 18x 8.5? + 30ish equip's, 1 cracked.
other:
3in dump/front pipe, screamer
3in straight through exh
bm44 brake master
ABS removed
wil also come with s14 steer rack with offset spacers which were used before when modded knucles were fitted until rhs one snapped, haha.
broken knuckles and a pair of stock 32 one's can be included as well.
cars 70% stripped but will come with stock seats and some trim etc
prob a few bits and pieces missing.
this car has legit rego with this engine but is currently un-rego'd due to using it as a track car, but can be re rego'd if needed.
car was dyno'd around last july on 98 pump with octane booster on 19psi and made 378kw and 580 Nm torque.
Price: 11000 neg
for more info or anything 0423387100, cheers jake. cars in sa
Attached thumbnail(s)
https://www.sau.com.au/forums/topic/376837-rb-25-r32/
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
