Hey everyone. I've got my dyne tune this week and just wondering what people have used to cover the hole on the gear box when the front shaft is removed. Also what one of the fuses do I pull out? Thanks.
Ps. I couldnt find the answer on google.
https://www.sau.com.au/forums/topic/376852-getting-ready-for-dyno-this-week/
I have driven a few hundred km with the front drive shaft out. On the S1 you go to the fusebox in the engine bay and there is a square green fuse for the awd - pull that out - your awd warning light should come on - that's as it should be.
Bloody he'll....should not happen....that is a thick oil IMO and should be fine. Any oil on the rear window of the car???.....if not have a look under the car for leaks.
I'm lucky if I loose 50mls in the VQ in 10000kms....even our race RB,s don't use that much.
P.s came in here to wish you luck on your dyno run.
ive had the car for 100000kms i service the car every 5000kms and every service i measure the oil and i always have lost 500ml every time. I use motul 5w40 but my car does not stop all day so mayby its understandable. My garage floor is pollished concrete so i know there is no leeks.
funny my 78 skyline c210 did the same 500ml every time weird i thought it was a skyline thing
mates c34 just got 230kwatw on e85 and the auto is shitting its self and he fills up every day.
keep us up to date with the resaults i want to get mine done soon.
I think it's done it the whole time I've had it :/. Oh well. I had this fear that the day before the dyno it would blow up or something and sure enough as of yesterday there is a horrible noise, sounds like really bad knock at about 4000 rpm. Another strange thing the hyper gear high pressure actuator holds a steady 14psi well up until the noise starts and I stop accelerating.
I'm curious why there is imperial sized nuts on a Japanese car. So f**king pissed off right now, I have a rounded nut now because I was using a 12mm spanner. Oh yay $165 for the tuner to remove the drive shaft. Just what I needed
Probably knocking its head off. 14PSI on a highflow with no tune is a receipe for disaster.
Yer, I actually forgot i was like WTF then oh yeah it's at yatala. If I can get 250kw il be happy that should be enough towing power.
Be interesting to see what it pulls. I use the same tuner. Shaun will leave it nice and rich and safe for daily driving.
I only get 258rwkw on 16psi with a gt3076R .82 IW
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
