i had 2 on my gtr one was faulty.. and one is still okay...
i bought them used and have done 2000klms in my car at 17psi.
sent turbos to gcg turbos to get checked out and they said one was still serviceable and one was stuffed... bugger...
i believe they fit onto sr20 and rb20 engine with t25 flange....
hope this helps.....
https://www.sau.com.au/forums/topic/37689-hks-gt2530/#findComment-758621
Serviceable generally means its still capable of service, ie, still working.
If its off a GTR it wont bolt straight onto an RB20 or a Silvia as the silvia was studs on the manifold whereas the GTR has the studs on the turbo and nuts on the other side of the manifold flange.
I dont suppose your interested in a trade in on a brand new GT30 are you?
DK
https://www.sau.com.au/forums/topic/37689-hks-gt2530/#findComment-781214
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
