Eg4 civic 1995 model si, colour red
all power options; power steering, power windows, aircon ice cold.
very fast car, runs 13.9 sec 1/4 miles
The shell has done 220k's however the engine approx 170k and was crack open and changed big end bearings ported the head and new springs and retainers with stage 1 cams.
The body has the usual amount of dings for a car its age and the clear-coat is starting to come off the drivers door.
Both front guards, rear quarters, cant rails and front bar repainted last year when i had the guards rolled and flared.
Serviced every 3 to 5k with valve clearance and compression checked on last service
No money has been spared mechanically on this car, listed below are all the mods i can think of at this time.
motor vti-r b18c 2 bottom end with type r head and stage 1 cams
Gearbox is a s80 with lsd type r box and has been overhauled with synchro replaced on
1st, 2nd & 3rd
factory limited slip diff
Lightened flywheel
Exedy Sports Organic heavy duty clutch kit
Fully adjustable camber kits front & rear
Upgrade to Disc brakes from a VTIR front and rear
24mm front sway bar
Skunk2 Shocks and springs
17 Inch rims with 70% tread on all tyres
All 4 Wheel arches have been flared, rolled & re-painted to accomodate big wheels as vehicle has been lowered.
Aftermarket alloy half size Radiator
Injen Cold Air Intake system
Skunk2 pro series intake manifold
Blox Racing Billet 70mm Throttle Body
Stage 1 Cams with new springs & retainers
T1R Response Headers
2.5" exhaust system
interior:
ek seats, ek center console, vti-r dash cluster with professional retro fitment
APEXI Power FC engine managment system with hand controller
Safe tuned to 109.3 KW ATW the car is tuned for response not power so still more power to be made with another tune.
Mugen Racing pedal kit
Nardi leather steering Wheel
Carbon fiber print vinyl covering the roof
1 year old pioneer head unit with four pioneer 6.5" speaker sound steam amp and sound 12" sub.
May swap really looking for cash offer $10,500 ono
Please contact 0452180559
https://www.sau.com.au/forums/topic/376907-95-eg4-hatch-b18c-civic/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
