Link to my Group Buy. http://www.skylinesaustralia.com/forums/topic/376916-whiteline-sway-bar-group-buy-r32-r33-r34-gtr-and-2wd/
I am organising a group buy for Whiteline Skyline Sway Bars. We require a MINIMUM of 5 orders to go ahead.
Front R32, R33 and R34 GTR;
BNF27Z; 22mm ADJ AWD RRP; $265 Me; $220
Front R33 and R34 2WD ONLY!
BNF24Z; 24mm ADJ 2WD; RRP; $265 Me; $220
BNF24X; 27mm Fixed 2WD; RRP; $265 Me; $220
Rear; R33 and R34 2WD & GTR ;
BNR11Z; 20mm ADJ; RRP;$299 Me; $240
BNR11XZ; 22mm ADJ; RRP; $299 Me; $240
BNR11XXZ; 24mm ADJ; RRP; $299 Me; $240
R32 2WD
Front; BNF 28Z: 24mm Heavy Duty Blade Adjustable. RRP; $265 Me; $220
Rear; BNR 26Z: 22mm Heavy Duty Blade Adjustable. RRP; $299 Me; $240
Rear; BNR 26XZ; 24mm Heavy Duty Blade Adjustable. RRP; $299 Me; $240
Front Links; R33, R34 GTR and 2WD (Not R32 GTR or 2WD)
KLC108; Front Heavy Duty Ball Link; RRP; $180 Me; $120
Rear Links; R32, R33, R34 GTR and 2WD
KLC109; Rear Heavy Duty Ball Link; RRP; $180 Me; $120
You can order any item individually, or all of the above to make your Skyline even more of a corner devouring beast!
Delivery is not included in this price, and rather than quote a "one size fits all" cost, contact me with your postcode for an accurate shipping cost.
The average shipping cost over the last 4 Group Buys I've run has been around the $20 -$30 mark; (insurance is extra).
As I live in Faulconbridge (Blue Mountains), all those wishing to come to me are welcome otherwise, I am happy to travel a reasonable distance in the Sydney area to deliver at no cost!
This is a great saving over retail, and an excellent chance to get hold of fantastic quality components that will really improve the handling of your wagon!
To stop this from dragging on for ages, I will requre FULL payment by Monday 3rd October 2011, and delivery is should be around 2-3 weeks later; 17th October onwards (actual delivery date may be a little earlier or a little later) depending on manufacturing lead time.
Please PM me for a shipping quote BEFORE depositing any funds.
Rest assured, I will be keeping in touch through the process, and in contact with all purchasers once they're ready!
Banking Details;
Dale Laughton
ANZ Bank
BSB; 012-836
ACC; 5333-44981
When making a payment, please use your forum user name as a reference, so I can confirm payments.
So let's get cracking!
Cheers, Dale
https://www.sau.com.au/forums/topic/376919-skyline-sway-bar-group-buy/
Am interested in front and rear 24mm bars and front and rear links for r32 Gtst. Could you pm me total price incl delivery. ( I'm in penrith so I can just collect from you)
Cheers. XD
That's great. Thanks for your support.
1Front; BNF 28Z: 24mm Heavy Duty Blade Adjustable. RRP; $265 Me; $220
1Rear; BNR 26XZ; 24mm Heavy Duty Blade Adjustable. RRP; $299 Me; $240
1KLC109; Rear Heavy Duty Ball Link; RRP; $180 Me; $120
Total is $580; I'll arrange a drop off for you; I'm in the 'Riff every few days.:thumbsup:
Payment details are at the bottom of the first post. PM me when you make a payment; so I can keep an eye out, and confirm as soon as it appears.
Cheers, Dale.
Wicked :) just quickly though what are people's thoughts in which swaybars should go where? Ie. Should I have a 24 for front and a 22 for rear etc?
Well for the front; you only have a 24mm to choose.
I'd be inclined to go with the 22mm rear, as if you go too large on the rear you'll end up with far too much oversteer bias. Also, you have an amount of adjustment to tune the rear with the 22mm bar anyway.
Of course; any first hand advice is welcome.:thumbsup:
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
