Installed a second hand alternator in my car a year ago hoping to fix a number of electrical issues and it helped but problems were still there
Over the weekend I trial fitted my mates alternator and my car had never run so well.
So basically I want to buy a band new alternator, any ideas of the part number for it? I believe Bosch sell a direct replacement.
Or does any one know the OEM part number(Not the Nissan number but the Mitsubishi/Hitachi part number)
Cheers for the help.
https://www.sau.com.au/forums/topic/376925-where-to-buy-a-new-alternator/
I wouldn't bother calling nissan, they will want approx $1,000 for an alternator. And yes - Thats the OEM price. I got a bigger bosch that bolted straight on, and even come with a little plug adapter to allow the engine bay plug to convert straight to the alternator. It was literally plug and play.
Took me about 15 mins to change.
The factory one was 80amp and the Bosch one was 85amp. Held better voltage than the factory one.
The bosch replacement was $280.
Rebuilding\ Servicing your factory one will cost about $300. Waste of money.
I'll try and find the number, if not, I am going to see my mate (who has my old engine and alternator) on wednesday afternoon, and I can take a picture.
I may have the box at home still so I'll look on that too in a couple of hours.
I ended up buying a $90 alternator from a wrecker and surprise surprise its not outputting 14v either. Put my mates alternator on my car and steady 14v.
Went to Ashdown-Ingrams in Osbourne park yesterday and purchased a brand new 85amp Bosch alternator. Look to be plug in as it had the connector to plug into the standard loom. I will fit it on the weekend and will post up model details if it all goon.
only cost $250 as well so will be very happy if it fits.
  • 5 months later...
I've recently bough a couple of second hand Hitachi alternators , one from Pick and Payless - 1990 300ZX LR180 (80a)$50 , and one from Pick a Part Dapto - 1995 A32 Maxima LR1110-705 (110a) $35 . The first owed me $54 for bearings and works fine on the old Subaru , the second $63 for bearings and with a bit of stuffing around will be for my S2 GTS25T . The Skyline has its original Mitsubishi 80a alternator and its plug is different to the Maximas Hitachi one . I have the Hitachis plug and sub loom so assuming it fits up ok the wiring should be straightforward .
I'd be interested to see the adapter provided with the above Bosch alternator if anyone has a pic . Something like that would make it easy to splice together an adapter wire to save cutting up the original loom .
That aside researching higher output alternators shows that they make higher output even at lower revs than some cars std alternators . Going from a 50 to an 80 on the old Roo showed no voltage drop at idle (14.3-14.5) and the headlights don't dim at idle anymore . It probably doesn't hurt to have this kind of voltage or similar at the coil or pump either .
Generally luxobarges get the highest output alternators because they have that much electric BS in them and the trendsetters want all that operating in quiet cars and when idling at the lights .
Anyhow I'll get back when its in and running , cheers A .
    • That may not be so tricky with a changeover relay (again, with LED indicator only to reduce load on existing headlight + source)  30 to indicator + globe side 86 and 87 to headlight parker + 87a to original indicator + chassis side 85 to chassis/earth repeat on each corner, sorted, no diode required
    • There might have been some "hard core" decalcification going on in the cells to create that noise As for chargers, I stick all our cars on a trickle charger every few months to "clean out their pipes/cells", the Mrs battery in her Mistsu ASX is still running its OEM from new battery 10 years on, and that thing does alot of short drives, and it can sit around for ages without a good long run
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
