Installed a second hand alternator in my car a year ago hoping to fix a number of electrical issues and it helped but problems were still there
Over the weekend I trial fitted my mates alternator and my car had never run so well.
So basically I want to buy a band new alternator, any ideas of the part number for it? I believe Bosch sell a direct replacement.
Or does any one know the OEM part number(Not the Nissan number but the Mitsubishi/Hitachi part number)
Cheers for the help.
https://www.sau.com.au/forums/topic/376925-where-to-buy-a-new-alternator/
I wouldn't bother calling nissan, they will want approx $1,000 for an alternator. And yes - Thats the OEM price. I got a bigger bosch that bolted straight on, and even come with a little plug adapter to allow the engine bay plug to convert straight to the alternator. It was literally plug and play.
Took me about 15 mins to change.
The factory one was 80amp and the Bosch one was 85amp. Held better voltage than the factory one.
The bosch replacement was $280.
Rebuilding\ Servicing your factory one will cost about $300. Waste of money.
I'll try and find the number, if not, I am going to see my mate (who has my old engine and alternator) on wednesday afternoon, and I can take a picture.
I may have the box at home still so I'll look on that too in a couple of hours.
I ended up buying a $90 alternator from a wrecker and surprise surprise its not outputting 14v either. Put my mates alternator on my car and steady 14v.
Went to Ashdown-Ingrams in Osbourne park yesterday and purchased a brand new 85amp Bosch alternator. Look to be plug in as it had the connector to plug into the standard loom. I will fit it on the weekend and will post up model details if it all goon.
only cost $250 as well so will be very happy if it fits.
  • 5 months later...
I've recently bough a couple of second hand Hitachi alternators , one from Pick and Payless - 1990 300ZX LR180 (80a)$50 , and one from Pick a Part Dapto - 1995 A32 Maxima LR1110-705 (110a) $35 . The first owed me $54 for bearings and works fine on the old Subaru , the second $63 for bearings and with a bit of stuffing around will be for my S2 GTS25T . The Skyline has its original Mitsubishi 80a alternator and its plug is different to the Maximas Hitachi one . I have the Hitachis plug and sub loom so assuming it fits up ok the wiring should be straightforward .
I'd be interested to see the adapter provided with the above Bosch alternator if anyone has a pic . Something like that would make it easy to splice together an adapter wire to save cutting up the original loom .
That aside researching higher output alternators shows that they make higher output even at lower revs than some cars std alternators . Going from a 50 to an 80 on the old Roo showed no voltage drop at idle (14.3-14.5) and the headlights don't dim at idle anymore . It probably doesn't hurt to have this kind of voltage or similar at the coil or pump either .
Generally luxobarges get the highest output alternators because they have that much electric BS in them and the trendsetters want all that operating in quiet cars and when idling at the lights .
Anyhow I'll get back when its in and running , cheers A .
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
