Thanks Cam,
Apexi dont do R32 stuff in the states, hence no English manuals... even the generic one for PFC is to suit an RX7. This is a HCR32 specific PFC.
Cheers anyway
Ciao
https://www.sau.com.au/forums/topic/37693-apexi-faq/#findComment-759333
is it the Apex Engineering RB20DET powerFC? If you have the jap manuals if you can scan the pages, I might be able to translate them for you
Unfrortunately I bought the PFC second X Japan. Hence no manuals. I have however done a search and found that the GT-R waste gate control is on Pin 25. In my car (HCR32) that has no wire to the loom.
My PFC has a boost control socket, and I know some people run Apexi EBC on this model, even though the catalogue has no listing.
Will look for Japanese information and give babble fish a run. May need to take you up on that offer.
Regards
https://www.sau.com.au/forums/topic/37693-apexi-faq/#findComment-759467
LOOKED EVEN ON AP Engineering Site.
Surely someone out there must be running RB20DET PFC and a EBC that can tell me where the solenoid gets supplied from... (Well, a link to ground. The Solenoid is powered constantley - as is the AC idle up solenoid.)
Maybe I just plug EBC into ACC so if I turn on the A/C the boost will increase...
This is becoming desperate
Regards Tom
https://www.sau.com.au/forums/topic/37693-apexi-faq/#findComment-759794
    • I thought it was just if “the modification effected/caused the incident”
    • Ok, good to know. I have open loop I think, I forgot which ones which but I am running the o2 sensor, brand new and I got a new boost solenoid because my last one was faulty and overboosting by a lot, but it's still technically overboosting. Haven't really bothered to hunt it down as I don't send it hard regularly.
    • You should not be able to see much smoke behind you if the mixtures are good - for ~13-14 psi anyway. It's not like you need to be running hell rich for only that much boost/load. Your tune might be a tad too rich. The tuner might have done that because they like to run a lot of timing. It's impossible to know what's going on from here. It won't be the actuator. It won't be the MAP sensor. Regardless of if by "MAP sensor" you mean either the Neo ECU's boost sensor (which is literally only that, a boost sensor so that the ECU knows a) that it's achieving boost, and b) that it is not overboosting) or you mean the dash gauge's MAP sensor (because it can't have any effect at all), or you mean the boost controller's MAP sensor (because it is very unlikely that it is running in closed loop, and so it is effectively just used to know when the pressure goes positive and so you can see the boost on the display, for the most part).
    • Yeah, they'll find anything they can. "Oh aftermarket ecu, that doesn't comply with emissions" lol.
    • See, I still thought it was 10 posts, and she was at 7 so I couldn't be bothered going in and fixing it when the fix was to simply post 3 more times. 8 more times....perhaps I should have.
