Texi Results
If you’re in Australia and need a one piece tail shaft give propeller shaft repairs in concord a call. They do all the big Sydney cars and they don’t vibrate at all don’t get one either cv joints, they bind and cause the vibrations
By drifter17a · Posted
Want to change and monitor if it robs again could be my harmonic balancer is gone do you reckon it can be bent crank , don’t believe so at 600+ hp that would shop very quickly so can think either harmonic on way out or at somepoint in car life it wasn’t tightened so balancer wobbled -
You do you. But I always resist changing things that don't matter, in favour of spending and doing on the things that do matter.
Cover is damaged per picture I uploaded so want to change it. Do you reckon balancer could be f**ked and need changing? -
No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
