Hi Guys,
just wondering how many of you have replaced the engine fan with a Thermo model instead. For a daily driver, wife to work and back... Me having some fun on weekends..
Did a search for Options and this looks like the go..... Any preferences opinion on this?
And if so ball park cost.....:thanks:
The clutch fan is almost guaranteed never to overheat the car. There is drag on the engine but it is fairly idiot proof compared to some of the issues that can come with thermofans (from appropriate shrouding to decent thermostat control).
There are numerous threads in forced induction from memory on the pro's and con's.
To go against the trend a bit here I have a 16" Davies Craig & have never had overheating problems be it in heavy traffic, on the dyno, etc, etc
So many people on here (not saying the guys above) make it sound like it can't be done without issues but like anything, if done properly, it can...
I hope my post didn't come across like it can't be done, it can. However you want to go in with your eyes open as there are potential issues.
I would love to remove the clutch fan for a reliable thermo but last time I looked (admittedly a while ago) I decided it would be cheaper and easier to go with another stock clutch fan.
What thermostat are you using wlspn?
Im using this to control my thermofans.
http://www.spalusa.com/store/Main.aspx?p=itemdetail&item=FAN-PWM-V3
On my 180sx I used ba falcon twin fans controlled with a greedy unit. It took temp reading from the factory ECU sensor. It controlled both low and high speeds of the fans and when aircon switched on. It lasted on there about 2 weeks before I replaced it with the clutch fan.
The temps always fluctuated within 10 deg where as the clutch fan keeps them within 3. The factory clutch fan is a heap more consistent and easier.
I don't think there's a Thermo fan on the market that can push the amount of airflow a clutch fan is capable of pushing.
I've used thermo setups before, and eventually gone back to the old clutch style fan. Simple and effective.
Yep, exactly what I thought easy and simple.
My 2009 ford ranger still uses it so... Why not.
@ 165 for a new one why not? Anyone had one of these go die?
Would love to know....!!!
No, as I said in my post, that wasn't aimed at anyone in this thread or anyone in particular, have just seen guys on here stating that a thermo will always cause overheating, etc & it's stupid to use one.
Just wanted OP to realise it can be done but as you say there are things that can go wrong or be done wrong...
When I first fitted the thermo it was due to cooler piping & I preferred the idea of that rather than removing the standard shroud or trimming blades as some people do.
My cooler setup has now changed & I could run the clutch fan again but currently have no reason to as temps are very steady under all conditions...
Nothing wrong with the clutch fan. It does its job superbly & is basically idiot-proof.
Fan is controlled by my Haltech (through standard temp sensor) with an over-ride switch
Edited by wlspn
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
