  • Replies 40
Ive taken some pics and will upload tonight if not tomorrow.
i also have the centre console bracket, $10 should do for that.
no boot carpet though.......
pm me when its a good time to pickup
hey guys, for those who have pmd or are awaiting parts im terribly sorry, mrs was in hspital for a bit so i havent been on.
outstanding parts ar being sent today for those waiting.
i will respond to all pms today at some stage.
1320053511[/url]' post='6087463']
do you still have exhaust manifold for turbo and if so is it t3 or t4?? eboost 2 still available?
both sold mate sorry, have t3/t4 turbo which needs a rebuild and split dump for ext wastegate available.
  • 3 weeks later...
sorry mate only have coupe lights.
Remaining parts left:
Rb20det assembled block and head only - suit rebuild $200
R200 Diff - $300
Harmonic balancer - $90
Power Mirrors both sides - $60 per side
Rear taillights - 2 door - $60 per side
alternator - $100
Rear crossmember - $80
T04E Turbo needs rebuild $80
Split Dump 9stainless) suit t04e with ext gate - $100
Fujitsubo catback - $150
Climate Conrol unit - $50
Knock Sensors - $50
Tailshaft - $100
Rear bumper brackets - $50
Engine mount brackets $50
Power window/mirror switch from drivers door card - $70
Rear lower 1/4 interior trims - good condition - $50 per side
centre console trim - $60
Lower dash to centre console trim - $60
Rear brake 2 pot calipers - $100
Narva Blue Power h3 headlight bulbs NIP $50
Orange indicator lights - $50 per side
Drivers headlight - $60
That all i got left.......the rest will go with the shell.
Ian
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
