Rich and retard. Its an ecu failsafe to try and protect the motor from being overboosted.
makes sense. what sort of pressure does this normaly happen at. What are the symptoms? black smoke, lacking power, or does it cut out
Happened to me at only 10psi in my old car. As soon as I hit boost 2500, it comes on nice and hard then all power and torque vanish after about 4500rpm. Its flat shit the whole way. Don't usually see too much smoke from a stock ecu. Wait til you go aftermarket, this BMW driver was swearing his nut off after tailgaiting me then me planting it and shitting black shit all over him.
That is a very good reason to keep the stock ecu. Our maybe next time one of these idiot perth drivers tailgates me I'll just richen it up to 9 to one while I'm driving. And plant it. Thanks for the good idea.
hahhahahahahaaa,, I can just imagine this....
"HERE TAKE THIS DICKHEAD" then fowl your spark plugs, engine stalls, pull over on side of the road.... get your head punched in, change / clean spark plugs.... drive home.
who is the dickhead now ? LOL
and about R&R, look at the maps on the R33 to understand it more.
Hmmm...my plugs wouldn't foul for starters as when intercooler pipes have come unclamped it has run this rich and not fouled or stalled. Secondly I am a fit 6"1 92kg 31 year old man. Who was going to punch my head in again? Not many. As far as dickheads go I would say that driving so close to someones car that it is risking your rear bumper is being a dickhead. I had a f**king truck run into me in traffic a few weeks back cos he was driving like an idiot and tailgating me. I am not happy about tailgaters :rant: So imagine this...you are tailgating a white skyline, your car gets covered in soot cos you were being a dickhead and tailgating me. Then when you get out being all macho you see me get out. Then you either apologise and get back in your car or get knocked out. My patience is gone for that sort of shit. So if anyone gets any ideas then please get out of your car so I can release some frustration on you and your car.
Ive read the term R&R being used quit often on the forum, in regards to the std ecu when too much boost is seen. think my car is suffering from this on occasions. what is it exactly
It a region on the airflow vs rpm maps in the ECU where the mixtures are very rich and the timing very low. The ECU doesn't expect the engine to ever get to those cells in normal operation, and that implies that there is some kind of fault so extremely conservative fuel/timing is used to protect the motor.
Bumping up the boost increases airflow and pushes the ECU into the R+R region of the maps.
No, it's a separate map of TP vs RPM that when the TP goes over that threshold timing is pulled and fuel added.
That being said, the top ends of the factory maps are so rich it's not funny, over a certain point the injectors are fully open! (saw 150% duty cycle :laugh:)
Rich and retard as others have stated are just an area of the factory map which would normally be called a "hole" a poor tuner had left in a map - but argueably done intentionally when airflow gets high in parts of the rev range for reasons best known to Nissan. Possibly done to protect the engine? Not that I know of anyone having reliability issues when tuning the car properly in those zones. I think it was a stupid way to let the car leave the factory, personally.
Short Samoan guys would be a good bunch to avoid in the first instance:
:whistling: Best policy is not testing the waters to find out, as naturally the one who does will no doubt be the one you didn't expect to be able to.
Maybe I am wrong on this - I was sure I've seen snapshots of this part of the map, so you are saying that regardless of the AFM signal etc there is a certain amount of timing pulled and fuel added? I would have thought this would have been more noticeable in a standard car, but you stand on the gas with the stock boost control etc and have no issues.... then add airflow and suddenly have the massive detuned sensation.
So where does the TP Load Limit table come into it then?
What I am saying is that while that top corner of the map is extremely rich (look at the required duty cycle to reach the target AFR in those cells, it's up around 150%), there is a table called TP Load Limit, which is the "afm (boost) cut" that people talk of. It tends to be maxed out in the lower RPM and decreases as the RPM increases. When your TP goes over this threshold is when "R&R" is encountered. What the ECU actually does in this instance I'm not sure (as in how much timing and fuel is altered and where it is referenced from, I do not know).
TP load limit is a hard limit for cutting fuel. If it hits TP load limit you WILL know about it.
R&R is a protective area on the last 2 columns (especially the last column) of the map which both increases fuel and even more drastically decreases timing. It is especially prevalent around the 4000 to 5200rpm area - you can imagine this visually by looking at the dramatic timing drop in the last cell. It is airflow based so efficiency improvements will also contribute to getting into this area as well as boost - the initial signs typically start around 9psi and getting dramatically worse towards 14psi. The onset of R&R is much more gradual than TP load limit. Kinda like developing liver disease as opposed to being shot.
Edited by simpletool
Mate you'd be pissed too if your car got hit by a truck. I reckon best policy is don't tailgate and your car will stay clean. :thumbsup: Here comes the soot :ninja:
Back on topic r an r is gay. TP load limit will make you shit yourself when it happens. Had both and fixed them with a power fc :merli:
I'm pretty sure there is MIN and MAX TP tables, separate to the TP Load limit.
I will load up NIStune when I get home and take some screenshots.
Ok, this is from the nissan_ecu_tuning_basics.pdf on the NIStune website..
9. TTPmax & TTPmin
TTPmin = “Total Theoretical Pulsewidth Minimum”. This value sets the absolute minimum injection
pulsewidth. This is in case a calculation (eg: unusually low reading from AFM) results in an injection
pulsewidth which would cause the engine to stall. Normally this value is only adjusted if different injectors
are fitted. Multiply all values by the ratio of old injector size vs new injector size.
Similar deal for TTPmax. It limits the maximum pulsewidth that will be used under any conditions and
values are modified in the same way. Watch out if TTPmax is set too low – it will limit the injector
pulsewidth and you won’t be able to richen the mixtures no matter what values you put in the fuel maps.
12. TP Load Limit
Commonly referred to as “Boost Cut”. Many tuners set all values to 255, effectively eliminating boost cut.
But a better strategy (assuming boost has been increased) is to adjust the values so that a boost cut still
exists but at a higher level. Values refer to TP, so work out what your max TP is and then adjust the
numbers in this table to slightly over this figure. This gives protection if boost control is lost (which can
easily happen if for example the hose to the WG actuator becomes damaged or dislodged).
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
