I Blew My Head Gasket and in need of replacemt. Just wanting to know what the standard thickness is for and r33 skyline?? Im pretty keen to get a cometic kit off ebay and just wanting to know if i should get a thinner or thicker one and will i have to get my tuned again if i do.. Its standard internals runnin 10psi on stock setup currently 220rwhp an a SAFC 2 tune any info would be appreciated. i had a look and there is very little information around thanks
Buy a standard head gasket. You don't need anything different
You also need to find out why you blew the headgasket.....it's not very common in these engines unless there are tune problems or overheating issues. Both of which, will not be corrected by choosing MLS for a head gasket
You blew your headgasket with 220rwhp and you want to upgrade the headgasket?? There are people making 500rwhp+ on the standard head gasket. As Elite said, focus your efforts and $$ on the reason why it blew.
use the genuine Nissan head gasket like it was said above head gaskets don't fail on there own accord. if you over heated and your head is wrapped it will leak no matter what. and i was running 17psi for 3 years on my rb25 and never had an issue with the stock head gasket.
Edited by Greekos
We've seen more like 1000hp on the standard ones with no problems. The issue this guy is going to have is he will put on a commetic and, as stated above, if the surface grind is not perfect, the gasket will not seal properly and it will end up blowing out. Then there will be another person bagging out commetic gaskets as a result.
When i pulled out 6th cylinender spark plug it was wet (the only one so im guessing its from this location).... The previous owner screwd the thread up on cyliner 6(Cross threaded) and the plug goes in on a slight angle and not sure if all the way down as it should but still it goes in secure and i think most of the way. Could mayb the position from where it fires mite have any affect on the gasket.... And is cometic an upgrade i would have just thoughtit just better quaity so just longer lasting.
Its a metal gasket so yes its anupgrade to handle more boost it does not mean quality is better. Nissan gasket is high quality it just isnt metsl but as proven by many its up to the task of high poeer and boost also has advantage of being ALOT more Forgiving in the surface flatness.
This is HUGE for a standard engine. Different thing if you are rebuilding an engine and have everything apart and can take your time getting all the surfaces perfectly flat.
Standard Nissan Headgasket vote from me!
If the spark plug is cross threaded then while the head is off get it fixed. This should not even be something to think about. Just do it. Think of a motor as being a mathmatical equation, if just one calculation is wrong then the end result is wrong. Your motor blew a head gasket, hmmmmm, what could have caused that ?
Thanks for the replies so is this option a safe one:
http://www.ebay.com.au/itm/Nissan-OEM-Gasket-Kit-RB25-RB25DET-ECR33-R33-Skyline-/200230253955?pt=Motors_Car_Truck_Parts_Accessories&hash=item2e9ea73583
Yeah not sure why it blew it has never overheated and is always run on tuber timer... It had been running rough on cold starts and idel (as if if it was missing) for a couple of weeks before it blew (when it heats up its fine) I though it mite by the water in the chamber. they day it did properly blow huge amounts of smoke one day it was sitting in a driveway on idel for about 15 min .
Does anyone no the thread tap size and pitch for the spark plugs
Turbo timer has nothing to do with it.
Detonation usually as a result of too much ignition timing or overheating. Considering you ruled out overheating, that is probably not going to be the cause. the running rough for a couple of weeks would have been due to water getting into the cylinder and causing a wet spark until the heat evaporated it or it blew out the exhaust.
The spark plug thread you should let your engineer fix it when he does the cylinder head service.
and buy the gasket from Nissan, stop frigging around with Ebay and cheap shortcut options. Get the proper gear and do it right otherwise you'll end up doing it twice
Also:
RB25DET engine gasket kit comes with everything you need to overhaul your engine. Kit includes new seals, o-rings, valve seals, stock headgasket, intake manifold gasket, exhaust manifold gasket, throttle body gasket, chain tensioner gasket, AIV gasket, turbo outlet gaskets, valve cover gaskets, spark well gaskets, and many more!
The above listing for the link you provided - WTF is a spark well gasket?
The picture shows a gasket set for an RB26 but the listing says RB25. It also says EVERYTHING you need to overhaul your engine.
I don't see rings and bearings? And if I'm being a picky cunt, it's also missing the half moon seals
just order the gasket from Nissan they really arnt that expensive!!! and it will blow agian if you dont work out whats going on, i mean who is to say that when the plugs been threaded metal shavings have gone into the cylinder and stuffed up the bore, gasket and pistons!
You said you have a SAFC 2 tuned on there and making 220hp mabe the tune on that is shit and detonating its head off? what fuel are you putting in it 98? what is the SAFC tuned for?
seems odd seing i made 256hp with stock computer, stock side mount just a pod and 3" exhaust on 9psi?
Go get a vrs gasket kit from just jap or kudosmotorsports comes with everything you need for head rebuild all genuine nissan parts and probably costs less then just buying a HG alone from nissan.
you posted asking for advice. listen to it! it's sound. you don't need a fancy MLS gasket. you need to do a few simple things.
step 1, find out why it blew a headgasket. they do not just fail due to misalignment of the planets. there has to be something wrong for a headgasket to blow out.
step 2, buy VRS kit from nissan or some retailer. justjap have the RB25 kit for $280. http://www.justjap.com/store/product.php?productid=19740&cat=&page=1 that kit includes the headgasket plus all the other little head bits you should be replacing.
step 3, remove head and send it off for head service, that includes getting the cross threaded plug hole fixed and anything else it needs.
step 4, get block checked and if needed get it machined too (probably get away without it but check it to be sure)
step 5, refit the head using the GENUINE NISSAN VRS kit.
step 6, ?????
step 7, profit
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
