I WD-40 THE HINGE ON THE TURBO & IN ''N' WHEN I ACCELERATE THE BOOST+10. BUT BEFORE IT GOES TO 0. WHATS WRONG WITH THE BOOST WHICH WAY IS TI SUPPOSE TO WORK.
NEED SOME HELP :worship:
What is this, a random phrase generator?
Not every set of put together randomly picked car related words makes sense.
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012476
His socks are probably still wet as he got off the boat into a skyline. With that said, I am guessing he squirted WD40 on wastegate flap and saying something about in neutral it goes to +10 which is probably wrong considering the nissan gauge is +7-7. You will most likely never create positive boost on the stock turbo in neutral. Your gauge is probably shit. + is positive boost - is vacuum, or negative boost if you wish.
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012518
i dont know all the parts of the car especialy turbos .ive got a boost controler. thats how it went +10 in ''n' first time it didnt do it again.the question is why would the car do that.
PRIVILEGED PEOPLE WITH R33 .$12.500 my life acomplishment
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012600
Ok I get it now. The Sarge is correct. Now that I've read it a few more times It does make sense.
You won't create any noticeable positive pressure while in 'N' because of the lack of load on the engine. Make sure your gauge is accurate by checking against another one
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012663
if your some kind of mechanic ,doesn't mean u can drive .it means u work 4 $18h :thumbsup:
Maybe where you come from pal. In Australia being a mechanic means not only can you drive but you get paid $30 an hour upwards.
http://www.seek.com.au/Job/heavy-vehicle-diesel-mechanic-wa/in/perth-perth/20651329
Edited by Room42
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012666
exactly and they wonder why theres a skills shortage..
I found a job the other day fixing pallets, was shift work but paid over 1000$ a week..I know blokes earning twice that pushing a broom at the desal plant..
Its crazy but truth is by giving people with no qualifications money often means they will spend it with qualified people which lets qualified people can charge what they likeand the people paying dont care cause they make heaps of money for nothing.....its the circle of life
at the end of the day though the broom pusher is more expendable than a qualified mehanic.If there was a war the broom pusher will be on the frontline getting shot at while the mechanic will still be fixig cars ,or tanks..
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012728
Who in their right mind would work for $19 an hour if they were a qualified mechanic? You get paid more packing shelves at the local supermarket.
Exactly....but would I be happy packing shelves at a local supermarket? Hell no.
Obviously you have the potential to earn more with a busy employer or a large company in need but Mechs are the lowest paid trade in the world
https://www.sau.com.au/forums/topic/376997-turbo-boost/#findComment-6012873
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
