R34 Gtr Alloys 2 Sets With Yokohama A050's
Set of R34 GTR alloys with caps, (VG condition) fitted with Yokohama A050 M 245/40/18 semi slicks around 1/3 worn evenly, $1600 for wheels only and $1500 for tyres or $3000 all up
2nd set of R34GTR alloys with caps (GC) 2 fitted with Dunlop DZ03G (fair condition) and 2 unmounted $1500
2 new (stored in cellar ) Yokohama A050 M 245/40/18 tyres $1000 (save $150)
Price drop for quick sale as follows,
1st set $1400, tyres $1200 all up $2500
2nd set $1200
A050's $900
  • 4 weeks later...
  • 3 months later...
  • 1 month later...
 Share
    • Standing around having photos taken on insta. (sad but true). Go to a track day, what is actually there nowadays could suprise you, you need to update your cool car in the hill radar to include VW, Hyundai, BMW etc
    • Hello again, I just want to tell you that i found the reason why my bnr32 is going out in right corners. I had my car tuned by a company and they fitted the Emu Classic and a new fuel pump in 2021. I checked the loom, changed the walbro fuel pump with a Deatschwerks fuel pump. None of this helped. Then I checked the fuel pressure and thought I was crazy. It was tuned with over 7 bar ( over 100psi) !!! But why? So I checked the fuel return line and saw that it was closed. That was probably also the reason why the tuner replaced the fuel pump, but he tuned the Emu with the 7 bar 🫣 The map in the emu has now been changed and evertyhing is fine.
    • I'm going to vote for considering going to the effort to close the lash down to the minimum. My bro-in-law got around to checking the clearances on the 3SGE in his Caldina. Was a bit fat all over. New shims at lowest allowable lash, and the car is remarkably better to drive. It appears that the increase in both total lift and duration that you get from doing this is worth a lot more than you might expect. I have been having evil (and expensive and time consuming) thoughts about doing it to mine, and I don't even think I have a problem. Not that I'd know, though.
    • Thanks for that, it actually sounds fine to me. What oil weight are you running and what kind of oil pressure do you see around idle RPM and a bit over it?
    • https://youtu.be/CCHaKUhZi34?si=PNdluupk9TWFtvws
