Hi Guy's,
Thought I might offer this to you as I am doing the M35's.
you guy's will have to dictate the kit that you want though....I presume that your gearbox's are the ones below.
http://www.summitracing.com/parts/TRG-RE4R01A-HD2/
or
http://www.summitracing.com/parts/TRG-RL4F03A-HD2/
I will buy these in group buy's to reduce the shipping cost.
Cost for install minus the kit will be about $200 to $250 and you bring your own oil + your car to me. I will look at the possibility of doing a mail setup like the M35's as soon as I can sus out the first kit.
If you just want the kit without me installing there will be an extra charge of around $30.
let me know your thoughts.
cheers
Craig
https://www.sau.com.au/forums/topic/377021-c34-slushbox-auto/
Do these give you sencond gear chirp like all the cool kids in their VN's?
I don't want something that is uncofortable to drive or more to the point, annoying to drive. Do you know of anyone who has used these kits in their C34?
.....I don't know if you with get the fully sic shift of the homodores as I have never owned one.
But I will tell you if you are thinking of cranking up your Hp this is has been a good choice for the m35's.... Shift is shorter and smoother at low rpm and much more direct under full power.
Your choice I'm just offering it!
Not sure if this will even fit a s2 sabbai... The S2 gearbox is RE401B - the part listed there is RE401a(series 1)...
What is the difference in the gearbox?.....is it just clutches or the Vb....I'll try and find a kit tomorrow as there was quite a few to choose from.
Like I said...just trying to help you out....the more info you can supply me the more chance I have of sorting it for you.
Not too sure the exact differences think somebody else may be able to chime in with the specs...
Either way your offer to help buy is appreciated jetwreck
From what I can find so far there are only these kits
http://m.summitracing.com/search?keyword=Transgo%20nissan
Any of these suit?
Will go to the transgo site tomorrow and have a bit more of a look....I have seen these gb's built to handle big Hp in the past.
Edited by Jetwreck
series 1 RE4R01A-good for 320ish rwkw with shiftkit
series 2 RE4R01B -good for 250ish with a shiftkit, then 320ish with kevlar clutches etc
so that would mean:
series 1 RE4R01A = http://m.summitracing.com/parts/TRG-RE4R01A-HD2
Blurb from the Transgo site.
Corrects/Reduces/Prevents: Planet burnup,
3rd clutch failure; Forward clutch burnup;
Soft 1-2 shift; Band burnup and low lube flow.
Has High-Temp, Low Shrink Sealing Rings.
series 2 RE4R01B = cannot find one on the Transgo site ( http://www.transgo.com/sk_nissan.php ) ......does anyone know of any other kits available?
this is true. a built S1 box can handle moar and are used in 800hp drag applications.
bubba destroyed a shift kitted uprated S2 box with ease.
I wish , i have destroyed several S.1 boxes, in my R31 that where built up,with 370rwkw, i then went glide..much better , the only real tuff box of the lot is the 3A, the rest are fairly so-so
MV's do the S.2- $385.00
use a RE4R03A gearbox with the transfer case from a RE4R01A which are available on 300ZX, patrols, pathys.
it can be built to handle 1000hp with uprated full manual valve bodies, transbrakes, billet servos, wider band, stronger clutches etc.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
