Clearing out some old stuff and i have for sale.........
Nismo clear indicators (new in box, unused)-$80
Headlights, front and rear, lenses look fine, no haze, rear housing has some cracks and breaks but all work fine
perfect to replace damaged or broken ones (comes with wiring loom and bulbs)-$250 set will separate if you only need one
R33 4door S1 rear lights, have been sprayed to look similar to S2 lights, paint can be removed to look standard using thinner. $180 set will separate if needed
K&N pod filter- used and abused needs a wash but its pretty decent condition, no rips or tears-$40
R33 gtst pod adaptor w/nuts and bolts- will sell for $10 to whoever buys the pod but $20 sold separately.
more to come.....
(will also attach pics this arvo)
Will post all of these anywhere at your expense or pick up at Upper Coomera.
Pm me offers or swaps.... also these will be on ebay as of this arvo also.
https://www.sau.com.au/forums/topic/377027-r33-gtst-new-and-used-parts/
bump!!!
also now selling front and rear bar from an s1 r33 gtst
front bar indicators can be included or sold separately they have led strip running lights installed in place of factory fog lights.
front bar has had back section cut to fit intercooler.
Colour is ice green- no scratches or dents, all in good condition. selling only due to upgrading to bodykit.
yep they are off a standard s1 bar, fog lights backs have been cut off but indicators are fine and fog lights have been replaced with led strips . all bulbs included, pm me ur ph no and I'll mms u pics. looking $40 for the set posted.
Edited by long33
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
