Hey guys, just wondering if all powerFC computers have a plug for a hand controller? Because mine has no sockets for any type of plugs around the case?
As my mates pfc is identical besides he has the plug holes :/ so im a bit confused.. Is it just the outside case that is different?
Cheers
Im not sure what case they come with normally.. Mine bolts up to the original location - unlike my mates, he has to zip tie his up but has the holes for the controller.
So looks like ill have to pull te case off and see - is there anything i need to be aware of when taking the case off?
Mine is on an R33GTS-t so I don't know if it is different to the 32GTR, but it still bolts up to the original location - the cases are identical apart from the holes for the hand controller and boost controller.
Taking it apart is easy; kinda just like taking an amp apart - some screws and it then just pulls apart. You should be able to tell very easily if it has the socket for the hand controller - as far as I know all PFCs do.
I reckon someone has done a stealth install and just switched the cases, as I can quite eaily pull my PFC out of it's case and put it into the normal ECU case and vice versa. If you really get stuck I can dig up some photos - pretty sure I took some shots when I had it apart a while ago.
Normally your new PFc is supplied with 2-pieces of double sided tape, 50mm x 50mm, that's the mounts but it jambs in pretty tightly anyway.
Your case would also have an outlet for the MAP sensor (boost kit), not just the hand commander socket.
I altered mine by just using the Nissan covers.
I then get mounting brackets and it looks factory.
Yeh meant to be two sockets, mine has nothing..
It looks identical to a std computer with the mounts but has pfc logo on top.. Easily changable though.
So all pfc computers should have these plug sockets? And it should be under my case.. I can only hope!
Yep - all should have - unless you have a stock ECU in a PFC case?
How did you go?
Haha funny you say that.. because as i pulled the cover off i found no hand controller plugs etc.. so someone has just put a pfc case on the top.
Anyway i un screwed another circuit board off and discovered a "VS DATA ROM" veilside sticker on the computer chip underneath.. so im pretty sure its been chipped? as you cant tune a std computer, i believe..
plus i dont have a rev limiter, as std limits at 8200rpm for memory and mine goes past.. so someone has been playing around with this computer.
All i want to do is set my rev limiter at the moment and later on down the track once i get more performace parts etc ill need to get a tune.. would any dyno place be able to tune this 'veilside chip' or 'sticker' as i have read?
Why set the rev limiter? If u hit the limiter u run the risk of breaking ur oil pump.
Jap tuners leave the limiter high to avoid this, but they rely on the driver to avoid over revving
Yeh i was reading that the other day DVS JEZ, which i dont want to risk that.. So i was just thinking of installing a shift light, its the easier option. Anyone know of any good shift lights to install?
