Hi,
Having trouble picking 4x tyres for my RWD '06 Skyline 350GT so would like others opinions
These are the best prices I can get in Christchurch ($NZ Dollars) including alignment
225 40 19 Fronts / 245 40 19 Rears
Toyo T1 Sport - $1400 @ Scobie's Tyres / Tyres2Go
Hankook V12 Evo - $1400 @ Tyres2Go
Falken FK452 - $1280 @ Scobie's Tyres
Nanking NS2 - $1100 @ Tyres2Go
These are for street only useage. The factory OEM RE050A had very loud road noise and now are all bald (They lasted well, ~28,000km I think).
From looking at forums it seems the V12 Evo's are more popular than the T1 Sports, but that is because they are usually cheaper, so it seems that at the same price the Toyo T1 Sports are the better tyre, so I need to choose between T1 Sport and the cheaper FK452. I've been told that the Nanking NS2 are might be quite budget, so it's worth spending a bit more to get a better tyre.
Thanks
Mike
Yeah only comment is dont get the NS2's they are a very budget tyre. I dont have first experience with the other tyres but have heard good things on both the T1 Sport and the V12 Evo's so I think either will be great.
The FK452 are excellent and I would still be using them if I hadn't tried KU36s. I got good miles out of the 452s and they worked really well.
The T1S is reputedly also a very good tyre and given that they're less than 10% more$, you might be advised to try them. Although, I wouldn't necessarily expect them to last as long as the FK452 - they are supposed to be a whole performance grade up from the 452.
cheers
I suggest you check out tirerack.com before you get any of those. A little bit more work, since you have to order then, wire transfer money, then fit the tires but on the other hand, larger tyre range and lower prices.
A lot of people swear by RE001s (they last).
I can recommend a lot of tyres but none that last over 10,000kms :P
Edited by Peter89
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
