I have an 1990 r32 gtr, and i think i have low oil pressure.. Even when the car is warm the oil pressure doesnt go past 2.. On idle it sits at about 1.5. I heard froma few people that the gauges on the r32's are faulty, has anyone else had the same problem?
https://www.sau.com.au/forums/topic/377054-r32-gauges/
Your oil pressure should be fine.
Could be the gauge itself or just be the sensor / sender itself, over time worn out.
Shouldn't be a big job, just get your mechanic to take a look and replace whatever is worn.
Aftermarket gauges are more accurate though, so if you put an after market oil pressure gauge in, it might fix the problem.
https://www.sau.com.au/forums/topic/377054-r32-gauges/#findComment-6013469
